268 cam valve clearance - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 8th, 10, 07:20 PM Thread Starter
Will I have PTV clearance problems with this cam and flat top pistons? .477in , .480ex. I installed it to factory specs, but the cam has a 4* advance built into the grind of the cam. Thanks
1967 coupe
bautino95 is offline
post #2 of 4 (permalink) Old Apr 8th, 10, 08:08 PM
Bill
Re: 268 cam valve clearance
Tino,
You shouldnt, but also depends on which valves are in your heads. 2.02 intakes start to get pretty close at .500" lift
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #3 of 4 (permalink) Old Apr 8th, 10, 08:11 PM Thread Starter
Thanks for the reply. Right now I have the 1.94/1.50 valves. That makes me feel better before I start the car.
1967 coupe
post #4 of 4 (permalink) Old Apr 9th, 10, 04:52 AM
Double check that your timing chain set is 100% correct.
I have 2.05" and ,538" lift with more duration and no clearence issues.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
hhott71 is offline
