Raw gas smell when driving? - Team Camaro Tech
post #1 of 9 (permalink) Old Apr 10th, 10, 08:55 AM Thread Starter
Hi All,
Took a 40 minute drive the other day , all highway at about 65 MPH and noticed the car had surges of strong raw gas smells that would come and go?
Would last about 30 seconds and then go away...10 minutes later would come again? Any ideas? Guessing carb may be on the blink?
thanks
Joe
faninc is offline
post #2 of 9 (permalink) Old Apr 10th, 10, 09:11 AM
Skip
Skeeter55's Avatar
Re: Raw gas smell when driving?
Check your gas cap.... Also check and smell your oil at the dipstick for gas..
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #3 of 9 (permalink) Old Apr 10th, 10, 09:11 AM
Brandon
Gas smell coming from front of cab or from back of cab? From front, check your fuel lines to and from fuel pump to carb. If from rear, then your burning way rich which could be a dirty air filter, bad plug (s) that are fowling jets that are too big or your floats need adjusting as your braking and the fuel is sloshing forward and dumping in causing a rich factor and going out as unburnt fuel.
Brandon J. licence 1NASTY67
Nantooch is offline
post #4 of 9 (permalink) Old Apr 10th, 10, 02:01 PM
Fred
And one more thing. Fix it NOW! You could be seconds away from burning down your car.
128.79mph 1.428 60'
Fred Ficarra is offline
post #5 of 9 (permalink) Old Apr 10th, 10, 09:18 PM Thread Starter
Raw gas smell was from inside the car while driving- on highway. Would be a surge smell and then go away and then come back a few minutes later no braking while occurring...thinking of just swapping the carb out.
thanks
J
faninc is offline
post #6 of 9 (permalink) Old Apr 10th, 10, 09:55 PM
Rubber fuel lines?
BPOS is offline
post #7 of 9 (permalink) Old Apr 10th, 10, 10:27 PM
Rich
Do you still hav the charcoal caster under the hood?Do you still have the large vacum hose that T's off the PCV valve hooked to the caister along with all the other hoses?If you have the canster but not all the hoses,the chances are you are getting fuel vapor escaping out of the recovery system.Either remove the canister and plug ALL the lines and find a way to vent your gas tank elsewhere,or hookup all the hoes.
RichSchmidt is offline
post #8 of 9 (permalink) Old Apr 11th, 10, 12:58 AM
AJ
Surging= incorrect ignition timing. period.
Incorrect timing, and ignition curves will cause all kinds of problems at speed.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #9 of 9 (permalink) Old Apr 11th, 10, 05:15 AM Thread Starter
yes I do have a rubber fuel line from the fuel pump to the carb, is that a problem? Rubber line is new.
thanks
J
faninc is offline
