No Timing Advance - WHY!! - Team Camaro Tech
post #1 of 9 (permalink) Old Apr 10th, 10, 11:03 AM Thread Starter
Rob
UGH! My car was purchased from a very non-mechanical woman. It has a chevy SM crate engine, MSD box, coil and distributor. I was setting the timing today and noticed the timing did not advance with RPM. There os no vacuum advance on the distributor. I pulled the cap and saw the weights were "locked out". I think the car was a track car a couple of owners before due to the 1150 CFM carb, HD powerglide and 12-bolt rear. I do not race and have replaced the carb with a 600 cfm and OD tranny. I am sure if I get the mechanical advace back, I will get better performance for weekend cruising.
But - why lock out the advance???
Dynawolf is offline
post #2 of 9 (permalink) Old Apr 10th, 10, 11:12 AM
Harry
dawg's Avatar
Re: No Timing Advance - WHY!!
It is common to eliminate both advance mechanisms so that the engine will be at full advance at all times. You will have a few less things that can fail, and setting the timing will be less of a hassle. It is manily these reasons that race cars run \"locked\" timing. as long as it will start ok theres nothing wrong with locking the advance.
Also it enables motors with big upper end cams to gain a bit of off the line torque.
434 stroker
US Navy retired
dawg is offline
post #3 of 9 (permalink) Old Apr 10th, 10, 11:41 AM
Ron
Yep a Straight Line WOT Track Star ;o)
If you're on the Street, I suggest you find a Dizzy with a Working Mechanical and Vacuum Advance. Be sure to set an Initial Timing, check the Vacuum at Idle and choose a Canister approx 1.5 to 2 Hg's below it.
This was my 70 1/2 Z28
Z15CAM is offline
post #4 of 9 (permalink) Old Apr 10th, 10, 07:29 PM
Larry
larryh56's Avatar
x2 on the street both mechanical AND vacuum advance are necessary for your car to run well.
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #5 of 9 (permalink) Old Apr 10th, 10, 10:02 PM
Steps
No
The VA will start pulling the intial up as it will be coming in...in practice about 1 to 2 " over still pulls all the way in, As the advance increases so does the idle vac. the general rule of thumb is same as idle.
Steptoe is offline
post #6 of 9 (permalink) Old Apr 11th, 10, 01:05 AM
AJ
I don't see how the race motors can idle at full advance and not gain any... So the centrifugal advance is all in at idle and remains the same?
I know with vacuum added it's pretty common to get around 50+ degrees, but minus the advance, what do these motors idle at, and at say 6,000rpm what is the timing? same as idle? I don't see how the timing couldn't increase thought the speed of combustion is increased with rpm.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #7 of 9 (permalink) Old Apr 11th, 10, 06:56 AM
Ok, If its locked out with no adavnce, what degree is the timing locked out at? 30,32,34,36,38 etc....?
This can be debated, There are some guys who run locked out dizzy's on the street and some say run vac adv or just mech adv.... The problem with a locked out dizzy is its great for performance but murder on starters.... If this a street car that will see several starts, I would worry about kickback and broken stater noses, and worse even broken blocks around the starter mount..... Locked out timming is not great for a car thst is like a daily driver, or you drive often IMO......
But you have to be careful how you interpret information from these forums... If this is a daily driver, you want to talk to guys that daily drive their cars, but too often guys try to cross daily driving and race practices and it is just breeds potential unhappiness........ Guys will say "I did this too my car and it runs fine" Then you ask them, how often do you drive it, and they say 500-1000 miles a year if that.... Weekend warriors or Seasonal warriors........... I like to talk to the guys that drive their cars 5+ days a week......
Stay as close to OEM as possible..... I have seen more OEM with a few mods last longer than, Fully moded forged etc....
shonuff is offline
post #8 of 9 (permalink) Old Apr 11th, 10, 07:07 AM
Patrick
If the car had a 1150cfm carb on it I think going to a 600cfm may be too small for it. Give us some engine specs.
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/[email protected],1/[email protected],Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
speedfreek is offline
post #9 of 9 (permalink) Old Apr 11th, 10, 08:08 AM
Let's say you are locked at 36 degrees. Race motors spend little if any time on the lower part of the centrifugal curve anyway. If your curve has your full mechanical advance in at say 2,800 and you launch your drag car higher than that anyway, no need for mechanical curve. (Timing would be the same 36 at 6k rpms)
Likewise if you have a mild engine, stock curve, 16 initial, 18 vac, and a couple mechanical pulled in at idle, you may have 36 at idle. So it's just about the same thing as the drag car at idle.
The 50+ you suggest is a combination of initial, high vac so the can is all in(cruise condition), and an RPM high enough so that the mechanical is all in/very high. Say, part throttle highway cruising at 3,500 rpms.
Melrose RS is offline
