What do I have? Anything special? - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 10th, 10, 06:46 PM Thread Starter
Patrick
I had this engine laying around and now I've decided to rebuild it. I thought it was just a regular TBI engine. Mortec says the heads are a 95-98 Gen I crate motor. The block lists as 2or4 bolt roller 1pc rear seal. I found out also it has Mahle Hyperutectic pistons in it (101ST7). These are the same pistons that come stock in LS1's. The cam is a roller but I cannot find the specs anywhere. Here are some numbers I found on it: 17-773-CPC-CCBC. The crank is just a cast one.
The heads look like TBI heads. I don't plan on using them. I have a set of vortecs for this engine. I plan on re-grinding the cam if it's nothing special.
What do I have?
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/[email protected],1/[email protected],Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
speedfreek is offline
post #2 of 3 (permalink) Old Apr 10th, 10, 06:53 PM
Bill
Re: What do I have? Anything special?
Nothing special. Mahle makes a lot of oem pistons. Most Vortec engines have them. I doubt that they are the same pistons as an LS1, the bore size is different.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #3 of 3 (permalink) Old Apr 10th, 10, 07:16 PM
The factory roller is nice, even nicer if it's a 4 bolt main. It might not have a provision for a mechanical fuel pump.
BPOS is offline
