Waterpump rebuild kit - Team Camaro Tech
post #1 of 15 (permalink) Old Apr 12th, 10, 08:13 AM Thread Starter
mbrekke's Avatar
Anyone have a source for a waterpump rebuild kit? The disc that the fan mounts to in particular. Thanks
68 327 4-speed 3.42 posi and a sunroof
best so far... 13.25 at 106mph
78 Firebird 350/T350 3.23 posi
65 Mustang convert. 6 cyl. 3-speed
66 Mustang coupe 6 cyl. auto
80 Chevy C10 406 4-speed
mbrekke is offline
post #2 of 15 (permalink) Old Apr 12th, 10, 12:30 PM
Re: Waterpump rebuild kit
Mark, I used to do this at our GM dealership , loooonnnggg ago. No one that I know now does this. But there is a man here in the Lubbock area, an old timer, that I heard of that is doing this for a living. Last I heard he had all the pump bearing assemblies and impellors to press into a the orginal housing. It was easy to do but if you did not have the correct plates and press equiptment, you would be likely to break the housings.
I presume you are trying to maintain your factory housing?
I have gone to a Stewart pump as they are the only people that know what a closed or open impeller is and does. In hardship cases , I have attached the FlowKooler disc, to make my over counter open impeller pump , closed.
TC # 349
zdld17 is offline
post #3 of 15 (permalink) Old Apr 12th, 10, 12:33 PM
ZZ_430's Avatar
Napa used to carry the kit, you might try them.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #4 of 15 (permalink) Old Apr 12th, 10, 01:32 PM
Roger
rogerh's Avatar
Check out this site. It is easy to break the water pump housing if not done right.
Roger
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
rogerh is offline
post #5 of 15 (permalink) Old Apr 12th, 10, 02:27 PM
If you want to pay to have it rebuilt-Arthur Gould, $80.
1969 Z28
1969 Firebird 400
My new project for 2010 DONE/ Sold.
2002 Camaro SS LE/SLP
67 Nova SS 327, M20, 3.73
nashcar is offline
post #6 of 15 (permalink) Old Apr 12th, 10, 02:31 PM
Kevin
KevinW's Avatar
Anyone want to try these kits out? $45 for Chevys http://www.waterpumpkit.com/waterpum...rpumpkits.html
Kevin
KevinW is offline
post #7 of 15 (permalink) Old Apr 12th, 10, 04:05 PM Thread Starter
mbrekke's Avatar
Thanks for the responses guys. I've got an original GM pump that only needs a new disc that the fan bolts to, other than that it's like new. Unfortunately I don't see the disc in those kits. Figures.
mbrekke is offline
post #8 of 15 (permalink) Old Apr 12th, 10, 05:04 PM
Kevin
KevinW's Avatar
Mark, just buy a junk one and swap discs (you need a press). Just beware, there are a couple of different ones (multiple bolt holes) and the shaft sizes changed in the later years.
Kevin
KevinW is offline
post #9 of 15 (permalink) Old Apr 13th, 10, 07:50 AM Thread Starter
mbrekke's Avatar
Thanks Kevin. Looks like that's the easiest fix. I was hoping loose waterpump parts were more available.
Hey Don, wanna stop by this weekend and rebuild my pump?
mbrekke is offline
post #10 of 15 (permalink) Old Apr 13th, 10, 09:29 AM
Even changing out fan hub on shaft, you will need to open up and support back side of bearing assy. Not a simple job if you dont have all the tools . Might be better off , letting Arthur rebuild the whole thing and make sure you have the enclosed impeller and be done with it.
TC # 349
zdld17 is offline
post #11 of 15 (permalink) Old Apr 13th, 10, 10:45 AM Thread Starter
mbrekke's Avatar
I see what you mean. Sounds like some good advice. Pressing the old disc off seems straightforward enough but putting the new one on would be a different animal. Thanks
mbrekke is offline
post #12 of 15 (permalink) Old Apr 13th, 10, 12:16 PM
Jeff
A guy on Ebay has the complete kit with fan:http://cgi.ebay.com/ebaymotors/Chevr...Q5fAccessories
Jeff
- 400 Dart Little"M", SRP 10.2:1, 4340 Scat rotating Assy, Solid Roller, AFR 210 Eliminators, Jesel shaft rockers,Super vic, Prosystems 847CFM, Tko600, 12 bolt 4:10 Eaton posi W/ Strange Hy-Tuf race axles and eliminators.
Best E.T. (11.96 @ 118.06) N/A
Classic Copper 4 Spd
jcdubs is offline
post #13 of 15 (permalink) Old Apr 13th, 10, 02:18 PM Thread Starter
mbrekke's Avatar
I'll have to check those casting numbers listed. Anyone know if short and early long pumps used the same internals?
mbrekke is offline
post #14 of 15 (permalink) Old Apr 13th, 10, 02:56 PM
Supposed to be the same, just differant shaft lengths and depths. Some of the newer bearing assys have the larger shaft id. Just need to know what you got, for street car , it dont matter.
TC # 349
zdld17 is offline
post #15 of 15 (permalink) Old Apr 13th, 10, 03:55 PM Thread Starter
mbrekke's Avatar
Muchas gracias Don.
mbrekke is offline
