2457 header fitment General consensus - Team Camaro Tech
post #1 of 13 (permalink) Old Mar 22nd, 11, 06:07 PM Thread Starter
DT
Donny
DT's Avatar
I have read many posts regarding Hooker 2457 BBC headers. Most all had fitment issues. Anyone have positive feedback with these headers ??? Please let us know.
DT is offline
post #2 of 13 (permalink) Old Mar 22nd, 11, 06:42 PM
Hector
Re: 2457 header fitment General consensus
I'm having issue right now on my BBC swap.. Correct engine stands and mounts and the 2457 still hit the stock power steering box..
Speedjester is offline
post #3 of 13 (permalink) Old Mar 22nd, 11, 06:49 PM Thread Starter
DT
Donny
DT's Avatar
Yeah Hector, Unfortunately I have read about that problem many many times before. Having said that, it seems to always be the case with cars that where NOT originally Big Blocks ? Coincidence, don't know?
DT is offline
post #4 of 13 (permalink) Old Mar 22nd, 11, 06:54 PM
Hector
I personally think it's the headers... Can't see how anything else changes... Seems they have a quality control issue...all you need is for the guy or machine welding at the jig to mess up 1/4 inch curve and it isn't going to fit
I can't see the subframe being off that much..and everything else lining up..
post #5 of 13 (permalink) Old Mar 22nd, 11, 07:13 PM Thread Starter
DT
Donny
DT's Avatar
Is the problem just the power steering??
DT is offline
post #6 of 13 (permalink) Old Mar 22nd, 11, 07:15 PM
Hector
For me it is...but I'm also having issues with the power glide shifter cable bracket...
post #7 of 13 (permalink) Old Mar 23rd, 11, 09:20 AM
Tom P's Avatar
on the plus side of these headers is how easy it is to change spark plugs with the 2457 headers. I can get to every plug with a socket and change plugs in a matter of minutes.
67 new build alum. 406 | 69 RS/SS 496 631 HP / 618 TQ | 73 Z28 Survivor 36k miles | 89 IROC Z 2500 miles | 02 SS 35th Anniv. LE 645 miles |11 SS Berger 550HP (1 of 25) | 14 ZL1 6M Recaros
Tom P is offline
post #8 of 13 (permalink) Old Mar 23rd, 11, 09:35 AM
Ed
BigBlock1969RS's Avatar
Bunch of threads already on this subject:
https://www.camaros.net/forums/showthread.php?t=193158
https://www.camaros.net/forums/showthread.php?t=156423
https://www.camaros.net/forums/showthread.php?t=74461
https://www.camaros.net/forums/showthread.php?t=177954
https://www.camaros.net/forums/showthread.php?t=174042
https://www.camaros.net/forums/showthread.php?t=129311
I had to clearance the flanges on my headers, to clear the head bolts, dimple 3 primaries near the P/S box (even with proper frame/motor/trans mounts) and fix the issue where the collector on the driver's side was not parallel so that I could install my exhaust system properly. They take work but can be made to work, but still don't have very good clearance hang down below the frame rails and the collector has a bolt flang reducing clearance by even another 1/2-1".
Ed
BigBlock1969RS is offline
post #9 of 13 (permalink) Old Mar 23rd, 11, 10:28 AM
Wes
I have 2457's on a 69 with a 496. They fit my rig perfectly though I don't have PS. No mods necessary at all and for BB headers, that says a lot. Pretty simple install; no PS, no A/C, 4-speed car, lock-out removed. I have AFR heads on this car and I probabaly had to grind on the flanges to clear the lower head bolts.
There's a good 5/8" clearance between the tube and my manual steering box so I'm thinking I'd have clearance if I had PS on this car.
If you're having clearance issues with the PS box, use these headers instead:
http://www.summitracing.com/parts/HOK-2205-1HKR/
Click on the on the photo and you can see how the number 5 tube is routed over the number 7 which provides all the clearance you need around the PS box. I use these headers on another 496 car with PS. But for these, I had to do some re-routing of the fuel line. No big deal.
As far as grinding flanges to clear the lower head bolts, that's a problem you'll likely encounter with any headers with aftermarket heads. Aftermarket heads and their bolts (or worse, studs) will cause clearance issues. Again no big deal. Simply mock up the headers, mark with a Sharpie the areas that need to be ground a bit, and go.
My sense is, many ask too much of the header manafucturers when it comes BB's. If you're running a BB, some adjustments to your new headers will almost always have to take place; even though you have the correct frame and engine mounts and the usually forgotten tranny crossmember. The tranny crossmember comes into play yet people forget; the correct BB crossmembers will move the rear of the engine toward the passenger's side of the car, away from the PS box.
Part of the fun of BB's. It's a huge difference vs. SB headers with 1-5/8" tubes.
You're playing in a different sand box now.
Straight-line-69 is offline
post #10 of 13 (permalink) Old Mar 23rd, 11, 11:19 AM
Banned
Bethanne
Nashville Beth's Avatar
The search for every last HP leads to these problems.
I've always had good luck with hedmans, but I also stick to the conservative side with primary tube diameters of 1-3/4" on BBC and 1-5/8" on SBC.
Until you get past ~500HP on a BBC, 1-3/4" tubes don't give up much.
But I deal with street engines. I do enjoy reading about all the stuff you racers have to overcome !
Nashville Beth is offline
post #11 of 13 (permalink) Old Mar 23rd, 11, 01:30 PM Thread Starter
DT
Donny
DT's Avatar
Yes Ed I know there are many threads on the subject. None of which really pertain to my question. I was looking to find out if anyone out there has power steering and had ZERO issues with the BBC 2457 headers. Thanks.
DT is offline
post #12 of 13 (permalink) Old Mar 23rd, 11, 04:08 PM
Hector
DT... I had my header problem fixed... Brought some spacer plates that go behind the motor mount..they come in 1/16 and 1/8.. I needed a total of 5/16 and the headers clear everything...and nice clearance to change plugs, oil filter and starter...wasn't as bad a fix as I thought as it was going to be...the owner of the local speed shop tells me he always has to exchange headers... One set may not fit so they exchange it for same part number just a different box and that usually solves the problem...
I guess it all about quality control...
post #13 of 13 (permalink) Old Mar 23rd, 11, 05:21 PM Thread Starter
DT
Donny
DT's Avatar
I'm glad it worked out Hector. Good luck to you.
DT is offline
