6.2 Carillo rods?? - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 28th, 11, 08:47 PM Thread Starter
Gary
6.2 Carillo rods??
thinking of building a new engine for my 67 camaro, finding 6.2 carillo rods on ebay for $100,, I understand the to good to be true theory but they are used.... sellers are 99% positive so they can't be total crap... wondering if a reconditioned $2400 set of rods would be worth anything but braggin rights? I am thinking AFR heads, forged crank,, maybe 400-450hp.. so cmon guys,, surely there are strong opinions on this subject...
and what is the detriment to using 6.2 V 6.0?
67 RS style is offline
post #2 of 5 (permalink) Old Mar 28th, 11, 09:37 PM
Steve69SS396's Avatar
Re: 6.2 carillo rods??
They typically use a rod like that in a large bore short stroke application for NASCAR. What pin and rod journal size are they? They probably have smaller pins and rod journals.
Steve69SS396 is offline
post #3 of 5 (permalink) Old Mar 29th, 11, 05:33 AM
Gary
Re: 6.2 Carillo rods??
Having a custom piston made with the pin at the correct height may cost more than you're saving with those rods.
Scat's "ProComp" (terrible name now with the cheezy ProComp products on the market) are the best bang for the buck, they'll fit stroker apps with no grinding and are tough, tough, less than $300 a set new. God only knows what those Carillos have been through...
Gary Adrian
FCS Harmony Racing
Momma always told me not to look into the eyes of the sun.
"But momma, that's where the fun is!"
Busted Knuckles is offline
post #4 of 5 (permalink) Old Mar 29th, 11, 06:14 AM
Steiner
What engine? What stroke? Anything more than 3.48" in a standard deck block and the piston is going to be all skirt.
'69 Camaro
500hp/538lbft
Steiner is offline
post #5 of 5 (permalink) Old Mar 29th, 11, 11:54 AM
Or a set of CompStar profiled rods. They are just as good for a street situation for about ľ of the cost.
TC # 349
zdld17 is offline
