1969 396 fuel line - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 30th, 11, 06:07 PM Thread Starter
DT
Donny
DT's Avatar
1969 396 fuel line
What fuel line are guys using from pump to carb, without the GF 432 filter, on a 1969 396?? I have a long water pump and the 3 piece line for the 396/375hp doesn't fit. Could I just cap the vapor return on the GF 432 filter if I go that route??
DT is offline
post #2 of 3 (permalink) Old Mar 31st, 11, 10:40 AM
Re: 1969 396 fuel line
Which carb? I was able to use the 68 396 QJet line with just a few tweaks to the bend to make it work with the passenger side alternator on my 69 Qjet equipped car. Less than 15 minutes it was on the car and flowing.
Eric
Eric Kammerer is offline
post #3 of 3 (permalink) Old Mar 31st, 11, 01:13 PM Thread Starter
DT
Donny
DT's Avatar
Really. I am using a Holley Street Avenger with dual inlets. I'm not expecting an exact fit , just something close I could tweak as you did. Is that a 3/8's line??
DT is offline
