1969 BBC fuel line - Team Camaro Tech
post #1 of 11 (permalink) Old Apr 10th, 11, 07:48 AM Thread Starter
DT
Donny
DT's Avatar
1969 BBC fuel line
Hey guys, having a tough time with finding a fuel line from pump to carb. I have a dual inlet Holley Street Avenger and was looking for a line that would be close, I could tweak it as needed. I thought the 3 piece 396/375 line (3/8)would be close, no dice, must be for a short water pump. I really need a single 3/8 line that would get me close to the carb. I have a filter by the brass y block. Already returned 3 lines. Shipping is expensive! Any ideas?? Thanks.
DT is offline
post #2 of 11 (permalink) Old Apr 10th, 11, 10:14 AM
Camarodude67
Re: 1969 BBC fuel line
Just got mine from Heartbeat for Z/28 302, I beleive it is same setup.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
Jeff G.
camarodude67 is offline
post #3 of 11 (permalink) Old Apr 10th, 11, 11:37 AM Thread Starter
DT
Donny
DT's Avatar
Thanks Jeff. If at all possible could you post a pic after you install?? Thanks for the reply.
DT is offline
post #4 of 11 (permalink) Old Apr 10th, 11, 12:32 PM
Ed
BigBlock1969RS's Avatar
You might check out The Right Stuff Detailing. They were able to make me a set of dual 1/2" stainless lines that followed the stock location. They have 3/8" listed on their site:
http://www.getdiscbrakes.com/RSeComm...Alphabetically
Ed
BigBlock1969RS is offline
post #5 of 11 (permalink) Old Apr 10th, 11, 12:51 PM
Kent
I used the ones you sent back, it took some serious tweaking but it turned out nice. I have a long water pump.
not the best picture, but I hope this helps.
Kent
Rally Sport is offline
post #6 of 11 (permalink) Old Apr 10th, 11, 05:28 PM Thread Starter
DT
Donny
DT's Avatar
Wow, Nice Kent!!! Thanks
DT is offline
post #7 of 11 (permalink) Old Apr 10th, 11, 07:07 PM
JohnZ's Avatar
Here's what that kit looks like on its original application ('69 Z/28).
JohnZ
CRG
JohnZ is offline
post #8 of 11 (permalink) Old Apr 10th, 11, 08:25 PM
Mike Montgomery
You can get a custom built line that looks absolutely correct here:
http://www.classictube.com/
michael montgomery<BR>69 SS 396/350
michaelm5 is offline
post #9 of 11 (permalink) Old Apr 11th, 11, 03:05 PM Thread Starter
DT
Donny
DT's Avatar
Great pic John, Thanks! Yes I have used classic tube once before. They want a mock up of the line. Last time I used a hanger for a mock up and they duplicated every little bend in the hanger, as a result the custom line didn't look to good.
DT is offline
post #10 of 11 (permalink) Old Apr 11th, 11, 03:26 PM
Vintage 68's Avatar
Talking Re: 1969 BBC fuel line
Originally Posted by DT View Post
... have used classic tube once before. They want a mock up of the line. Last time I used a hanger for a mock up and they duplicated every little bend in the hanger, as a result the custom line didn't look to good.
- for some reason I don't find that hard to believe at all
This time try starting with a piece of TIG wire to make their pattern
I've used standard 3/8" fuel line available from many auto and truck parts stores to make custom feed lines.
I have a couple nice benders, and fill the line with sand or cornmeal to prevent collapsed inner bend areas.
You'd be surpirized how good a fit you can get - maybe after a few practice funs if necessary ...
Once your done with getting it to fit, just flare the ends for the correct flare fitting.
1968 Convertible
Some trucks
Vintage 68 is offline
post #11 of 11 (permalink) Old Apr 11th, 11, 04:37 PM Thread Starter
DT
Donny
DT's Avatar
Thanks John, I have a very good bender. Its been so long since I have used it, I trashed 3 pieces already. LOL
DT is offline
