Vacuum pressure in oil pan?? - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 10th, 11, 11:35 AM Thread Starter
Hector
Well shut the engine off and heard a hiss.. Went over to the oil dipstick and as soon as I pulled it it sucked air in...I have never seen this before... I am running a pcv valve on the driverside head but have no breather...
Is this an issue??
Thanks in advance
68 Camaro Coup, BBC ,2457 headers, th400 , ford 9", Hotchkiss connectors,
Speedjester is offline
post #2 of 6 (permalink) Old Apr 10th, 11, 12:29 PM
Steve69SS396's Avatar
Re: Vacuum pressure in oil pan??
You need a breather on the other side.
Steve69SS396 is offline
post #3 of 6 (permalink) Old Apr 10th, 11, 04:06 PM
get a breather in the opposite valve cover.
you don't plan sincerity.
novaderrik is offline
post #4 of 6 (permalink) Old Apr 10th, 11, 04:08 PM Thread Starter
Hector
Ordered 2 from summit both were to big for the grommets...
post #5 of 6 (permalink) Old Apr 10th, 11, 04:55 PM
Autozone has some cheap plain chrome ones that fit. Kinda old school looking. That's what I use.
Sent from my iPhone using Autoguide
Melrose RS is offline
post #6 of 6 (permalink) Old Apr 10th, 11, 07:21 PM
darrell
you can change the grommet also--they have those at part house --
97Z4C is offline
