'68 heads - sender hole thread size? - Team Camaro Tech
post #1 of 8 (permalink) Old Apr 10th, 11, 02:15 PM Thread Starter
Guess
HwyStarJoe's Avatar
Question '68 heads - sender hole thread size?
What size NPT is the hole in a '68 cylinder head? I need to plug the hole and want to run to Lowes for a plug. I know it's a lot larger than in later heads.
Thanks!
HwyStarJoe is offline
post #2 of 8 (permalink) Old Apr 10th, 11, 02:55 PM
Re: '68 heads - sender hole thread size?
1/2 inch NPT
post #3 of 8 (permalink) Old Apr 10th, 11, 03:27 PM Thread Starter
Guess
HwyStarJoe's Avatar
1/2?
It looks more like 3/4" or larger. The sender I took out of the old head was bigger than 1/2" and it's too small.
No biggy.... I'll just get a couple different size plugs and see which one fits.
post #4 of 8 (permalink) Old Apr 10th, 11, 04:50 PM
Joe pipe/hose is measured on the ID, so the out side is tube is on the OD, but the fitting
is normaly in a pipe fitting.
john68 is offline
post #5 of 8 (permalink) Old Apr 10th, 11, 07:01 PM
JohnZ's Avatar
Originally Posted by HwyStarJoe View Post
1/2?
NPT is National Pipe Thread, not a machine thread; a 1/2" NPT plug is about 7/8" on the O.D. of the threads.
JohnZ
CRG
JohnZ is offline
post #6 of 8 (permalink) Old Apr 11th, 11, 04:48 AM Thread Starter
Guess
HwyStarJoe's Avatar
Thanks John... I said NPT because I thought that's what the hole is. I took a handful of plugs and kept jamming 'em in there until one threaded. I guess it is machine threads now that I look at it. I didn't measure it... I was just happy there's no more hole in the side of the head.
Long weekend...
post #7 of 8 (permalink) Old Apr 11th, 11, 06:47 PM
JohnZ's Avatar
Long weekend...
All the sender and plug holes in the head are NPT, tapered pipe threads; there's no such thing as a sender or plug with machine threads.
JohnZ
CRG
JohnZ is offline
post #8 of 8 (permalink) Old Apr 12th, 11, 04:57 AM Thread Starter
Guess
HwyStarJoe's Avatar
Gotcha...
