Help me choose a serpentine kit - Team Camaro Tech
post #1 of 13 (permalink) Old Apr 10th, 11, 03:05 PM Thread Starter
Chris
I have a GMPP 350. I am running power steering, no A/C. I am considering the Billet Specialties kit and also the March kit they are both around $500.
I have heard the March can be a PITA. I have a clean slate and can go with anything I want so that may make it a little easier than trying to make existing parts work.
Two questions, what is the advantage/disadvantage to mid mount VS top mount alternator? Also what do they mean when they refer to keyed shaft vs press on?
This is the kit I'm leaning towards.
http://www.billetspecialties.com/ite...id=142&pid=742
Thanks!
shoddy_F-body is offline
post #2 of 13 (permalink) Old Apr 10th, 11, 04:36 PM
Sean
Re: help me choose a sepentine kit
I had no problem with the March kit. I think it look less "billety".
68 Convertible | stockish 350 | 700r4 | 3rd Gen Power Steering | Dual Electric Fans | MSD Ignition | Island Teal
GR8_68 is offline
post #3 of 13 (permalink) Old Apr 10th, 11, 04:42 PM
Sean Love your thermo, gasket, keeps the hot radiator air from the carb,
john68 is offline
post #4 of 13 (permalink) Old Apr 10th, 11, 05:49 PM
Tom P's Avatar
The only issue that comes up with the March setup is getting the PS Pump aligned perfectly. It may fit the first time or you may have to remove it and shim it with washers. I had the March black power coat on my BBC and just recoated them argent silver.
Clearances will dictate mid mount vs top mount. Either should fit on your small block. Mid mount will make it tougher to get to the fp fittings and lower wp hose - but no big deal.
Look at your PS pump shaft - does it have a "key" on the shaft or is it smooth (press on)?
67 new build alum. 406 | 69 RS/SS 496 631 HP / 618 TQ | 73 Z28 Survivor 36k miles | 89 IROC Z 2500 miles | 02 SS 35th Anniv. LE 645 miles |11 SS Berger 550HP (1 of 25) | 14 ZL1 6M Recaros
Tom P is offline
post #5 of 13 (permalink) Old Apr 11th, 11, 05:32 PM Thread Starter
Chris
Re: Help me choose a serpentine kit
Gr8 68, do you know which kit that is? I like that. What about the water pump and alternator?
post #6 of 13 (permalink) Old Apr 11th, 11, 05:49 PM
Sean
If you are looking for another option that is more "business" oriented and looks a little less blingy (is that a word... ) check out these guys and the kits they sell http://www.krcpower.com/products.html Check out their "Serpentine" or "Crate engine" kits.
On my new motor I need to go with all new brackets and pulleys but want a more business look and something that will work well also, I like the KRC or CV products stuff. A bit more $$ but not a lot more, and quality stuff too. Just an option to consider.
Sean
Franklin D. Roosevelt
68rs406 is offline
post #7 of 13 (permalink) Old Apr 11th, 11, 07:11 PM
Bill
Send a message via MSN to Orange68SS Send a message via Yahoo to Orange68SS
Since March did away with those PITA O-rings, I would recommend them now.
68 SS Camaro - 468 BB, Tremec 5 Speed, Wilwood Brakes, Curry 9 inch (370 gear)
Orange68SS is offline
post #8 of 13 (permalink) Old Apr 12th, 11, 12:10 PM
Sean
This is the kit I installed. http://www.marchperf.com/pg61.html
I used a Powermaster 105amp Alternater. But to be honest, the first one burned up and the second one was DOA. I went to the local Pick-A-Part and got one off of an Olds for $15.
The water pump is a Weiand. http://www.holley.com/9240P.asp
GR8_68 is offline
post #9 of 13 (permalink) Old Apr 12th, 11, 07:36 PM
Jason
69 Bowtie's Avatar
I have the March system and love it, of note, I have manual steering so I didn't have to deal with that.
69 X-44/ 427BB/ M22/ 12 bolt
Muscle cars, more expensive than crack!
69 Bowtie is offline
post #10 of 13 (permalink) Old Apr 13th, 11, 05:50 PM
March Serpentine components on my BBC......no issues with install.
David F.
www.firstgens.com
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
post #11 of 13 (permalink) Old Apr 14th, 11, 09:05 AM
Concept One makes very nice stuff too. My Concept One kit bolted up perfectly.
67 RS Convertible, 355ci, 650cfm, 5-speed, 12-bolt, 3.90 gears. 12.7 @ 110 mph
Marktat is offline
post #12 of 13 (permalink) Old Apr 14th, 11, 11:51 AM
GMPP makes a nice kit - not flashy though. For about the same dough, and includes WP, PS pump and alt. http://www.jegs.com/i/GM-Performance...oductId=752514
BPOS is offline
post #13 of 13 (permalink) Old Jun 6th, 11, 08:41 PM Thread Starter
Chris
Thanks for the input. I ended up going with the March and it was an easy install.
