Re: Cowl hood BBC ?
Well measured the cowl opening 15" measured the generic air cleaner 14" that should give me a half inch gap all the way around... Install big block kicks engine over 1" ... I'm off set on the cowl opening by half an inch....
Am I correct or am I missing something??
So if I wanted it to fit in the cowl opening I would need a 13" or 12" air cleaner... Sound correct??
What size air cleaners are the BB guys running to get up into the cowl opening?? Diameter and height??
Any help would be appreciated thanks..
68 Camaro Coup, BBC ,2457 headers, th400 , ford 9", Hotchkiss connectors,
