Motor built 10 yrs ago - never fired yet-Q's - Team Camaro Tech
post #1 of 9 (permalink) Old Apr 12th, 11, 06:36 AM Thread Starter
Rich
Well my 69 Z has been a back burner project(never ran since bought in 87) and the 302 I built has been sitting unfired for at least 10 years. I am thinking about lube and the first fire up, I have a old distributor that I use as a preluber so I plan on doing that, then turning engine over and doing it some more and also adding ZDDPlus to the oil, I was wondering if any one had any other suggestions before I attempt to start it?
69 R/S Z/28 302 X33 D80 late 09C
69 T/A clonification LS6-6speed under construction
15 ZL1
64 Chevelle wagon 6.0l planned sons toy
zman1969 is offline
post #2 of 9 (permalink) Old Apr 12th, 11, 08:04 AM
Re: motor built 10 yrs ago - never fired yet-Q's
Valve springs compressed for 10 years can't be good for them. Just a thought!
'69 SS 350! Bored .30 over and mated to a turbo 350 auto. 383 going in next week and a T-56 6 speed later this winter. Stock 10 bolt with drums on all 4 corners. Matts Classic Bowties full suspension/disc kit coming soon as well!
jsukey is offline
post #3 of 9 (permalink) Old Apr 12th, 11, 09:36 AM
alex
Re: Motor built 10 yrs ago - never fired yet-Q's
Rich .Dont be too quick about changing things my 70 s/s sat for 23/24 years and i got it running with a new set of plugs a set of points agood battery and some new gas. This is what i did two weeks before i started it i rolled it out of the garage .First i rigged up an electric fuel pump to suck out the gas from the tank. I got about 7 gals of orange stale gas but it was not as bad as i expected. Second i pulled all the plugs and sprayed w d 40 in all the holes with the nozzle attachment .I then went around again after an hour with a squirt can and MYSTERY OIL 3/4 good squirts each hole. I then put the old plugs back in finger tight let it sit a week. I then removed the plugs and with a good battery cranked it over everything turned and sounded fine. new plugs fresh gas and new points and she ran like i shut it off the day before no lifter tick and the oil was also 23 years old but fresh when i put the car away in 81. After it ran for a half hour i shut it off and then started to get it ready to drive again about 3,500and 8/9 weekends of work and we were back on the road since then i have spent every year and its been fun.Funny no matter how old you get when you get behind the wheel of something from your youth you feel 18 again .Hope this helps . ALEX
ss27 is offline
post #4 of 9 (permalink) Old Apr 12th, 11, 10:59 AM Thread Starter
Rich
thanks for the suggestions I will lube the cylinders too. BTW this is a new built engine and cam will need broken in too. no gas in car ever
15 ZL1
zman1969 is offline
post #5 of 9 (permalink) Old Apr 12th, 11, 01:03 PM
Look into what you should do to break in that new cam......I've heard that you have to initially run the engine at 1500 to 2000 rpm's for the first 15 to 20 minutes.
reelknots is offline
post #6 of 9 (permalink) Old Apr 12th, 11, 02:00 PM
Royce
New flattappet break in 2000-2500 RPM's for 20 minutes. No idling, get it fired and get the RPMs up. Have a fire extinguisher handy as well as a garnden hose, to keep the radiator cool if needed. You do not want to shut it off unless you have to. If you do have to shut it off, once you fire it back up get the RPMs back up until the 20-30 minutes at 2000-2500 has been met. Change the oil and filter after break in.
A little lube in the cylinders (WD-40 works fine), spind it over by hand a few times, while pre-lubing it and you should be good to go.
Royce (NO XQSSS) Bradley
camaroman7d is offline
post #7 of 9 (permalink) Old Apr 12th, 11, 04:49 PM
Chris
I have been wondering the same thing. I bought my crate motor close to 7 years ago and have not fired it yet. Hoping to this summer. I guess the motor doesn't know how long its been sitting.
shoddy_F-body is offline
post #8 of 9 (permalink) Old Apr 12th, 11, 06:03 PM Thread Starter
Rich
sorry, I was already to do this - I have broken several new cams in but not after its been sitting this long. guess its good for first Timers to see this. and I had one go bad on my 460 F+%& Torino and it really did a lot of damage all bearings, oil pump, cleanup block and pistons - second time I did it with only the outer valve springs- live and learn
15 ZL1
zman1969 is offline
post #9 of 9 (permalink) Old Apr 12th, 11, 09:58 PM
darrell
me personally i would remove valve covers and spray oil on guides and if you can find a pencil light to see in cylinders-if you see any rust -spray some marvel mistry oil in cylinders and it set a day or 2 before spinning over--man a true 302 they are getting rare good luck
97Z4C is offline
