Small block mount issues - Team Camaro Tech
post #1 of 1 (permalink) Old Apr 12th, 11, 04:48 PM Thread Starter
Jeff
Sorry guys!!! I've read so many of the discussions on engine mounts and frame mounts until I have confused myself. Here's my dilemma: I have the 67-68 frame mounts that were holding a 327 (210hp) motor, I'm installing a 350 and planned on using solid engine mounts which gave me issues. #1 The engine is closer to the firewall on the passenger side by a close inch. #2 The clutch fork will interfere with the firewall. My research and CORRECT me if I'm wrong indicates that the engine mounts are suppose to be 2 different sizes (shorter one mounts to the passenger side of engine) which will even out things under the hood. The clutch fork I'm using is a Lakewood to which will be replaced by a GM (1/2" shorter). My question is what brand and model number engine mounts are the best fit. I would prefer to use Energy Suspension if thats a option. Thanks!!
jeffscamaro is offline
