67 SBC 350 Oil Filter adapter question - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 13th, 11, 09:25 PM Thread Starter
Putting my 67 350 back together. Does it matter which way the oil filter adapter goes back on? Looks like it can go 180 degrees around and still bolt up.
Thanks!
nova67camaro is offline
post #2 of 4 (permalink) Old Apr 14th, 11, 08:40 AM
Vince
vincevs's Avatar
Re: 67 SBC 350 Oil Filter adapter question
The concave part should be down if I remember correctly...
One piece of advise: when you screw the center stud in (that recieves the new style filter) don't turn it all the way in. You want to have a solid 2 turns on the new style filter and if you turn the stud all the way in, that won't happen. Use the loctite provided.
Vince
69 Base Coupe "The Wrecker" Project -
67 rs/SS L48 4spd Convertible -
- SOLD
vincevs is offline
post #3 of 4 (permalink) Old Apr 14th, 11, 10:50 PM Thread Starter
wondering if the filter/diaphram should go into the block or away.
post #4 of 4 (permalink) Old Apr 15th, 11, 12:03 AM
Farm Boy's Avatar
1967 was the last year for the old canister oil filter. The adapter has a built in bypass valve and it doesn’t matter what position the bypass valve is installed.
Farm Boy is offline
