Is there a problem, If so what is it? - Team Camaro Tech
post #1 of 8 (permalink) Old Apr 15th, 11, 03:17 PM Thread Starter
Jeremie
Opened the hood today and saw what appears to be gas on the top of the intake. What would cause this? Why is it that once you get everything fixed something else goes wrong? I wish it would just stay fixed!!
Thanks for the help!
MTN10 is offline
post #2 of 8 (permalink) Old Apr 15th, 11, 03:20 PM
Hector
Re: Is there a problem, If so what is it?
Float bowls on tight?? Is it just wet in front??
68 Camaro Coup, BBC ,2457 headers, th400 , ford 9", Hotchkiss connectors,
Speedjester is offline
post #3 of 8 (permalink) Old Apr 15th, 11, 03:41 PM Thread Starter
Jeremie
Not sure about the fuel bowls being tight. I just had the carb off and the guy who built my motor jetted it down. I don't think the fuel bowls were messed with. It is wet on the front and down the whole sides to where the bolts hold it to the block?
MTN10 is offline
post #4 of 8 (permalink) Old Apr 15th, 11, 04:02 PM
Hector
I believe if they jetted it down they had to remove the fuel bowls to get to the metering block...
Try tightening the fuel bowls.. The four bolts in the picture... Sometimes the cork gasket tear or pinch...
Try tightening it...it should stop the leak.. Worst case you pick up a gasket..they do make a gasket that can be reused over and over..if you need to be changing the jets often..
post #5 of 8 (permalink) Old Apr 15th, 11, 09:34 PM Thread Starter
Jeremie
Hector,
Thanks for the help. I will try that.
MTN10 is offline
post #6 of 8 (permalink) Old Apr 15th, 11, 10:07 PM
Wes
Accelerator pump?
Straight-line-69 is offline
post #7 of 8 (permalink) Old Apr 16th, 11, 09:00 AM
Start it and see where it is leaking. Watch the fuel supply line connections very close. Some of them are very poorly made and just will not seal.
deerhunter is offline
post #8 of 8 (permalink) Old Apr 16th, 11, 09:03 AM
Originally Posted by Straight-line-69 View Post
Accelerator pump?
X2 or the bowl hold down bolt gaskets, little round ones.
TC # 349
zdld17 is offline
