Should I change the PCV valve? - Team Camaro Tech
post #1 of 7 (permalink) Old Apr 16th, 11, 09:51 PM Thread Starter
I have a stock ZZ383 GM crate motor with 18 inches of vac. at idle. I constantly have to clean away oil that seems to seep out from around the PCV grommet. I have the polished alum. center bolt valve covers from GM. They do NOT have baffles. The PCV valve is one that is specified for a Z/28 302 by Rick's Camaros. Should I change to a different PCV valve that is for a higher idle vac. than the Z/28. Would this help my oil seepage? A new grommet doesn't help.
The PVC venting is the OE setup with a cowl hood and matching air cleaner.
Suggestions?
Known to run with scissors....
__________
1969 Camaro Z/28 "clone", GMPP ZZ383, Autogear M22W, Moser 12bolt w/TruTrac 3:73.
Fred Mertz is offline
post #2 of 7 (permalink) Old Apr 16th, 11, 10:29 PM
Re: Should I change the PCV valve?
Use two PVC valves? I had to on my boy's truck.
Ron
The
An exercise in interchangeability on a Well optioned 67 SS 350 vert.
Geezer is offline
post #3 of 7 (permalink) Old Apr 18th, 11, 06:29 PM Thread Starter
btt
__________
post #4 of 7 (permalink) Old Apr 18th, 11, 09:40 PM
Yes. Definitely. I recently had this same issue. Changing from unknown PVC valve to correctly rated one cleared up the seepage around the grommets.
Sent from my iPhone using Autoguide
Melrose RS is offline
post #5 of 7 (permalink) Old Apr 18th, 11, 09:40 PM
Wes
First, you need valve covers with baffles for the PCV system. Are these GM valve covers? If so, they should have baffles.
Secondly, a stock 302 pulls about 13-14 hg of vacuum at idle, so yes, find a PCV valve that's for a milder engine; maybe one for an L-48 or something.
Straight-line-69 is offline
post #6 of 7 (permalink) Old Apr 18th, 11, 10:45 PM
darrell
gotta have baffles --it cant suck crank case pressure correctly with oil being constantly sprayed on pvc plus its gonna leak
97Z4C is offline
post #7 of 7 (permalink) Old Apr 18th, 11, 11:00 PM Thread Starter
The valve covers I have are the GMPP covers for the vortex center bolt heads. They have no baffle. I may try the finned Z/28 cover I have, they are baffled. With the vortex heads you can use either style covers
__________
