Spreadbore intake question.. - Team Camaro Tech
post #1 of 11 (permalink) Old Apr 17th, 11, 06:59 AM Thread Starter
Guess
HwyStarJoe's Avatar
Question Spreadbore intake question..
Stupid question....
Can I stick with an Edelbrock spreadbore intake if I swap a Qjet for a squarebore Holley? Is it just a matter of using the correct gasket\spacer?
Looking at this Holley for sale locally: http://www.summitracing.com/parts/HLY-0-80508S/
HwyStarJoe is offline
post #2 of 11 (permalink) Old Apr 17th, 11, 07:24 AM
STEVE
Re: Spreadbore intake question..
I have run square bore holleys with the adapter plate on several SBC, but never in a first gen Camaro.
Depending on which hood and air cleaner you are running you might have a height / clearance issue.
fast_in_muskoka is offline
post #3 of 11 (permalink) Old Apr 17th, 11, 07:44 AM Thread Starter
Guess
HwyStarJoe's Avatar
Cowl hood... 3" open air cleaner.
post #4 of 11 (permalink) Old Apr 17th, 11, 08:01 AM
Originally Posted by HwyStarJoe View Post
Stupid question....
Yes either will work. Square bore w/ adapter or a spread bore.
As for the height, I had a VicJr. under a flat hood with a dropbase filter. You should be fine
68 Camaro~LSx ~all motor
post #5 of 11 (permalink) Old Apr 17th, 11, 08:15 AM
As said, yes you can. Adapter plate is thinner now than before.
Mount intake and carb, then add a cylinder of clay and close hood.
Open hood and check height.
post #6 of 11 (permalink) Old Apr 17th, 11, 08:16 AM Thread Starter
Guess
HwyStarJoe's Avatar
The Qjet and Edelbrock 3" air cleaner don't quite make it to the cowl opening now. I can just see the top of it from inside the car.
Alright... it can be made to work then.
This should work just fine... http://www.autozone.com/autozone/acc...er=228351_0_0_
post #7 of 11 (permalink) Old Apr 17th, 11, 02:31 PM
Mickey
Moonpie's Avatar
I've used a stock spreadbore intake with a one inch adapter and Holley plus a 3 inch filter in my Camaro before. The Moroso air cleaner base had a half inch drop around the carb.
Moonpie is offline
post #8 of 11 (permalink) Old Apr 17th, 11, 02:55 PM
Steps
Have had a holley sq bore base plate with a Impco 425 carb on a performer spreadbore valley cover for 20 odd yrs
The spacer should have the divider plate in it.
I was able to mill a good 5mm off the spacer, which actually had the spreadbore base fit far more accruatly...like port matching.
used a drop air cleaner and the hold down bolt was/is so close to the hood it rubbs the paint off after a few weeks.
Steptoe is offline
post #9 of 11 (permalink) Old Apr 17th, 11, 04:16 PM Thread Starter
Guess
HwyStarJoe's Avatar
Thanks guys.... good info.
post #10 of 11 (permalink) Old Apr 17th, 11, 10:21 PM
Wes
Not sure what Edelbrock intake you have but if you have either the Q-Jet Performer or Q-Jet RPM Performer from the last 10-12 years, you can run either a spreadbore carb or Holley. No adapters needed. Here's the Q-Jet RPM Performer:
http://www.summitracing.com/parts/EDL-7104/
Notice the two sets of bosses for mounting either style carb.
Straight-line-69 is offline
post #11 of 11 (permalink) Old Apr 18th, 11, 04:51 AM Thread Starter
Guess
HwyStarJoe's Avatar
Right... mines a little older. The Smithsonian called once and wanted to use it in their museum.
It's a 7101
