motor locked up - Team Camaro Tech
post #1 of 18 (permalink) Old Apr 17th, 11, 10:06 AM Thread Starter
Cruzin "the 82"
angelglo's Avatar
motor locked up
ive got a 350 in my 75 K5 blazer that i have not started in about a year. Yesterday, I bought a new battery and tried to start it. It cranked a little bit then it cam to a sudden stop. I dont think it made a complete revolution. What could have possibly stopped the motor? I tried to turn the motor from the crank pulley bolt but no go. I am planning on pulling the heads to take a look. I want to ad that it ran perfectly when i last ran it a year ago. It was rebuilt by a reputable rebuilder about 5 years ago and only has about 1500 miles on it.
angel
angelglo is offline
post #2 of 18 (permalink) Old Apr 17th, 11, 10:22 AM
Re: motor locked up
Pull the plugs, check for coolant or water??
john68 is offline
post #3 of 18 (permalink) Old Apr 17th, 11, 10:26 AM Thread Starter
Cruzin "the 82"
angelglo's Avatar
Re: motor locked up
John, I forgot to mention the i did pull the plugs and sprayed the cylinders with lubricant. the plugs were dry.
angel
angelglo is offline
post #4 of 18 (permalink) Old Apr 17th, 11, 10:34 AM
Bill
bill3337's Avatar
Re: motor locked up
The plugs may have been dry, but could have had some water sitting in a cylinder, and water won't compress and will definitely lock up the engine and bend rods if you push it. With the plugs out, will it turn over?
bill3337 is offline
post #5 of 18 (permalink) Old Apr 17th, 11, 10:52 AM Thread Starter
Cruzin "the 82"
angelglo's Avatar
Re: motor locked up
bill, i pulled the plugs out so i can start it since i havent started it in a years. i sprayed lube in it since the cylinders were going to be dry. but it cranked maybe a 1/4-1/2 revolvution and stopper.
angel
angelglo is offline
post #6 of 18 (permalink) Old Apr 17th, 11, 10:54 AM
Re: motor locked up
with the plugs out?
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #7 of 18 (permalink) Old Apr 17th, 11, 10:55 AM Thread Starter
Cruzin "the 82"
angelglo's Avatar
Re: motor locked up
yeah. they are still out and no go. im planning on pulling the heads to take a look but i was wondering if any of you might have an idea as to what it might be so i do not waste my time by pulling the heads
angel
angelglo is offline
post #8 of 18 (permalink) Old Apr 17th, 11, 10:57 AM
Re: motor locked up
Before pulling heads, I'd do the following,
Pull the plugs, open the throttle, disable the ign, and have a lubricant ready in hand.
Remote starter button in place and as the engine spins over, squirt engine oil into every cylinder.
External charge battery, make sure cables are in good shape, large enough wire gauge, and fill the carb bowl with fuel.
Install plugs, undo WOT, and with a fresh battery try again.
post #9 of 18 (permalink) Old Apr 17th, 11, 10:57 AM
Bill
bill3337's Avatar
Re: motor locked up
Could be valves not closing as well. Stuck open and hitting pistons at top dead center. Pull the valve covers and make sure valves are opening and closing. You may be able to turn it by hand in reverse to check that out if it's already stuck.
bill3337 is offline
post #10 of 18 (permalink) Old Apr 17th, 11, 11:01 AM Thread Starter
Cruzin "the 82"
angelglo's Avatar
Re: motor locked up
thanks guys. bill, i think you might be right. I forgot about that. It has been a long time since i concentrated my efforts on engines. I kept thinking about the rotating assembly. I will pull covers and take a look.
angel
angelglo is offline
post #11 of 18 (permalink) Old Apr 17th, 11, 11:11 AM
steve
Re: motor locked up
The previous posts are good advice,here's something else to check. I had a starter drive gear break and get wedged against the flywheel not allowing the engine to turn.
grampstoyz is offline
post #12 of 18 (permalink) Old Apr 17th, 11, 11:20 AM Thread Starter
Cruzin "the 82"
angelglo's Avatar
Re: motor locked up
Thanks steve. I have a tilton high torquemini starter. I was under the truck to look around since it has a 12" lift. The starter is not stuck but i think that since it is a high torque starter, i might have bent the valves since if that is the problem.
angel
angelglo is offline
post #13 of 18 (permalink) Old Apr 17th, 11, 02:30 PM
Re: motor locked up
You did have coolant in it, 30 deg can split a block, once the water has been boiled it will freeze, and expand quicker, I split a block 13 places a 30 deg. and the car was in the garage, test ran, put it back in garage, had water on the floor next afternoon!!
john68 is offline
post #14 of 18 (permalink) Old Apr 17th, 11, 03:41 PM
Re: motor locked up
Just remember , if you have to do lots of work on this stock motor, I may be cheaper to buy a GM crate 350 crate motor and get going again.
TC # 349
zdld17 is offline
post #15 of 18 (permalink) Old Apr 17th, 11, 05:30 PM Thread Starter
Cruzin "the 82"
angelglo's Avatar
Re: motor locked up
john, If we see 30 degrees here in the SF bay area, it is big news like a tsunami. 3 degrees is rare.
Im going to be selling the truck so it really not worth it for me to buy a motor for it and it really isnt a stock motor so id like to save it if i could so i can sell the truck with this motor
angel
angelglo is offline
