327 engine mounts - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 18th, 11, 07:14 PM Thread Starter
Jeff
327 engine mounts
When converting a 327 to a 350, can I use energy suspension mounts and if so , what numbers are best to use?? I have read many confusing threads!!! Thanks!!
jeffscamaro is offline
post #2 of 6 (permalink) Old Apr 18th, 11, 09:46 PM
Ed
Re: 327 engine mounts
It all depends on which frame stands you have, that's the most important thing in which motor mounts are correct, look here
http://pozziracing.com/camaro_engine.htm
freezined is offline
post #3 of 6 (permalink) Old Apr 18th, 11, 11:15 PM
Jerod
I pulled my 307 out of my 1969 Camaro and will use the same motor mounts and frame stands on my newly built 350. Mine are factory GM, I do not know about aftermarket mounts. Thanks, Jerod
mjlynch71 is offline
post #4 of 6 (permalink) Old Apr 19th, 11, 05:39 PM
JohnZ's Avatar
If your new 350 has the thick 8" balancer, you may have a clearance problem to the sway bar using the 307/327 mounts and frame stands.
JohnZ
CRG
JohnZ is offline
post #5 of 6 (permalink) Old Apr 20th, 11, 03:38 PM Thread Starter
Jeff
thanks for the response!! Would you suggest I use the 69 mounts??
post #6 of 6 (permalink) Old Apr 21st, 11, 06:19 PM
Smile Re: 327 engine mounts
It really doesn't matter which mounts you use. If you have a 350 with the large balancer, by using the 302/350 mounts they will only clear a STOCK sway bar. If your sway bar is larger than stock you will have to shim the sway bar down anyway.
TJS69 is offline
