Can I use a sbc cam button on a gear drive timing set? - Team Camaro Tech
post #1 of 8 (permalink) Old Apr 19th, 11, 05:50 AM Thread Starter
Question Can I use a sbc cam button on a gear drive timing set?
I am going to be using a gear drive set, but also a retro-roller cam swap.
The retro roller cam kit requires the cam button to stop the cam from walking.
I have seen a gear drive set come with a cam button ... but I wasnt sure if it was the regular sized SBC one ( there is only one size right? ).
I am pretty sure the holes in the cam gear are the same on a roller type, and the gear drive type, right?
So I will just use the regular SBC type cam button, I wont need anything special?
THANKS ---
90' ZR-1 Lingenfelter Corvette #699
91' SYCLONE #512
01' VIPER GTS
03' Harley Edition f-150 #577
alwayscode390 is offline
post #2 of 8 (permalink) Old Apr 19th, 11, 06:24 AM
Ron
Re: Can I use a sbc cam button on a gear drive timing set?
What Type and Make of a Cam Gear Drive are you planning to use?
The Hi-End Cam Gear Drives such as a Donovan are encased with it's own timing Cover which incorporates an Anti-Cam-Walk Device (Forward Thrust and Back Kick Wear Plate Devices).
The Wear Plates are setup first to position the Lifter Roller in the middle of the Cam Lobe and the Thrust Device is adjusted to prevent the cam from walking forward with a cam lash of approximately .004".
It's common practice to drill a 1/64" (1mm) hole in the PSGR Tappet Oil Gallery to assist Oiling the Cam Gear or Chain and a 1/64" hole behind the Wear Plates through the front Cam Boss into the 1st Cam Bearing Oil gallery to assist Oiling the Wear Plates.
I highly recommend you stack Lube Impregnated Washer Type Wear Plates, which can also be drilled with numerous Holes for lubrication, DO NOT USE the Torrington Units.
I would use a Coyles Roller Timing Chain over any of the cheaper floating gear designs like the Peter-Jackson units. In which case I recommend using something similar to the ISKY Timing Cover Unit which incorporates a Hole Through Timing Cover with an Adjustable Thrust unit that bolts to the Back of the Water Pump. Never depend on the stock timing cover to hold the forward cam walk force - if you do - Epoxy a Metal Shim on the back of the Water Pump that butts against the Timing Cover in front of the Thrust Button Type - Don't forget to drill the appropriate Holes, the Wear Plates and lock the Cam to within a .004" End Play.
Remember to use a Bronze or Composite Distributor Gear if the Cam is a Billet. You can spend a little more the have a Billet Cam Ringed with a Cast Gear and use the OEM Melonized Dizzy Gear. If the Cam is Cast use the OEM Dizzy Gear.
Except for the Donovan Cam Gear Drive Unit, Summit has all the Equipment I've mentioned.
This was my 70 1/2 Z28
Z15CAM is offline
post #3 of 8 (permalink) Old Apr 19th, 11, 11:55 PM
darrell
everything ron said
97Z4C is offline
post #4 of 8 (permalink) Old Apr 20th, 11, 01:04 AM
AJ
Originally Posted by 97Z4C View Post
everything ron said
Second that. Unless you're dead set on using the gear drive, do some searches to view previous threads with the good, bad, and ugly of using them.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #5 of 8 (permalink) Old Apr 20th, 11, 07:31 AM
x3 and comments about the cast iron presson cam dist drive gear(Everwear) is correct, I am using the stock GM gear with my billet roller.
Also did the front timing gear oiling trick off the oil galley. Many miles on this set up with no issues after two teardowns. I am using the Cloyes Hex-adjust gear with chain and rigid Cloyes cover.
TC # 349
zdld17 is offline
post #6 of 8 (permalink) Old Apr 20th, 11, 07:57 AM
Royce
Yes you can use a cam button with a gear drive.
Royce (NO XQSSS) Bradley
camaroman7d is offline
post #7 of 8 (permalink) Old Apr 20th, 11, 08:25 AM Thread Starter
I just looked at the set I have.
Its a Pete Jackson noisy dual idler SBC set ... and it came with a cam (thrust ) button. Looks to be steel?
I took a pic of it:
Is this all I need to use when installing a retro roller cam for the front of the cam/engine? Then a wear plate to adjust the roller lifters to the lobes on the cam?
Great tips on the drilling, thanks a bunch!!! ---
91' SYCLONE #512
01' VIPER GTS
post #8 of 8 (permalink) Old Apr 20th, 11, 05:27 PM
2X you can use the cam button with the gear drive...roger that
68 Camaro RS/SS, 454 BBC,TH400,
Atth2o is offline
