Sb 350 carb or ignition problem. - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 19th, 11, 01:06 PM Thread Starter
Jimmy
Hi!
Have some problem with the engine on my Camaro 69, its a SB350 with a Holly 600cfm.
When I accelerate it hesitates somewere in second gear, and when I accelerate more it start to run fine again.
Were do I start searching, carb or ignition? suggestion?
Jimmy
Bosing is offline
post #2 of 6 (permalink) Old Apr 19th, 11, 01:21 PM
Re: Sb 350 carb or ignition problem.
I would check the timing, mech and vac. advance and dwell first since these are the easiest to measure. If all that checks out, then I would see if the accel pump is working correctly.
reelknots is offline
post #3 of 6 (permalink) Old Apr 19th, 11, 02:23 PM
Steps
What rpms ?
Check accel pump, float level and crap in the float valve, 1st..easest.
I assume its HEI??
If not as above..routine check dwell....
Which with pionts can be checked by checking timing...If the timing has changes its usually because of wear on pionts and dwell is out.
Check at night in the dark for Leaks in HT leads
Clean dizzy cap and rotor
Or Simply put, a routine 6 monthly maintance check.
Steptoe is offline
post #4 of 6 (permalink) Old Apr 19th, 11, 11:52 PM
darrell
power valve is wrong or shot-remove and inspect--take your vacuam at idle subtract 6.5 and you will be close enough on the number on power valve-then double chek timing and advance curve
97Z4C is offline
post #5 of 6 (permalink) Old Apr 19th, 11, 11:56 PM
Steps
yep thats the next bit...make sure u have spare gaskets, and give the new ones a light smear of oil...that way they will not break /pull apart/stick next time.
Steptoe is offline
post #6 of 6 (permalink) Old Apr 20th, 11, 01:43 AM Thread Starter
Jimmy
Ok, thanks for all the replys, will start problemshooting today. Will let you know when I find the problem.
Bosing is offline
