781 heads?? - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 21st, 11, 06:17 PM Thread Starter
Hector
781 heads??
Well after everyone telling me my top end might be weak.. Was wondering .
I have a set of 781 in my basement.. Would it be worth it to get them prepped with lighter valves..and maybe mill the heads down to increase compression..
Would it make a big improvement over the peanut ports.. If so now much..on a stock 86 454..
Thoughts opinions.. Thanks in advance
68 Camaro Coup, BBC ,2457 headers, th400 , ford 9", Hotchkiss connectors,
Speedjester is offline
post #2 of 5 (permalink) Old Apr 21st, 11, 11:14 PM
darrell
Re: 781 heads??
which heads are on it now-the 071s---in my passed reference, the small cc peanut heads have out done the 781s-the factory flow on 781s is much more--i have run the same set up with closed chamber head and then tried the 781s and lost 2 tenths--in my opinion hog out the peanuts -high flow valves and correct spring set up
97Z4C is offline
post #3 of 5 (permalink) Old Apr 21st, 11, 11:21 PM
Banned
Bethanne
Nashville Beth's Avatar
Re: 781 heads??
I would never sink $800 in a set of cast iron heads when the edelbrocks are $1500.
But if the budget is tight, bigger valves in the 781's would be the way to go. Use steel shim gaskets to help the compression.
Nashville Beth is offline
post #4 of 5 (permalink) Old Apr 22nd, 11, 03:15 AM
Ron
Re: 781 heads??
As Beth says consider the cost of rebuilding the 781's Vs a set of aftermarket Heads. One thing it's NOT feasible to change OEM Specs by Milling Heads over and beyond just smoothing the surface as you run into all shorts of incompatible problems. 781's require Domed Pistons to get the Static Compression up to a point where you can run a stout cam.
If you running OEM Flat Top pistons and on a budget you're probably better off with Closed Chambered 396 heads on a 454 to get the Static up to approx 9.1 and run something like a 270H-10 cam.
This was my 70 1/2 Z28
Z15CAM is offline
post #5 of 5 (permalink) Old Apr 22nd, 11, 10:01 PM
darrell
Re: 781 heads??
yep -i agree with yall
97Z4C is offline
