327 to 383 - Team Camaro Tech
post #1 of 11 (permalink) Old Apr 24th, 11, 07:56 AM Thread Starter
Tony
Send a message via AIM to tony -Di
327 to 383
Hey all Happy Easter . I have had a 327 chey engine in the back of my garage since 1976 with the hopes to redo it when i have the time . most of you know what i mean lol.any ways its a 2 bolt main with double humped heads so my questions are one can this block be changed to a 383 ? and can it be changed to a 4 bolt main ?
thanks
tony
tony -Di is offline
post #2 of 11 (permalink) Old Apr 24th, 11, 08:41 AM
JAY
Re: 327 to 383
Greetings from Arizona
not sure about 327 to 383, but if you want 4 bolt main and your motor isan't already machined I'd think it would be better to find 4 bolt main block or buy 383 crate motor and start from scratch. I just helped a friend do 350 to 383 in his 66 Chevyll..its a runner now he's building 406 for his 49 Stude PU Jay
66 SS Chevyll
67 Elcamino
68 Malibu 2dr
69 Camaro Convertible
JAYARTER is offline
post #3 of 11 (permalink) Old Apr 24th, 11, 09:33 AM
Jeff
yellow69RS's Avatar
Re: 327 to 383
thanks
tony
Yes to both. The 383 requires a 4" bore your 327 has that. It's possible to add splayed 4 bolt caps to a two bolt block, not sure if it's really necessary , depends on how you set it up for power/RPM.
Jeff
yellow69RS is offline
post #4 of 11 (permalink) Old Apr 24th, 11, 09:51 AM
Robert
ROBS6T8's Avatar
Re: 327 to 383
Next question... where to get a good 383 rotating assembly? Where do you stop HP wise for all forged bottom end? Sorry for the hijack.
Robert
68 Camaro SS... getting there!!
"If happiness is in your destiny, you need not be in a hurry."
If I can only convince myself of this!
My slooow build thread
ROBS6T8 is offline
post #5 of 11 (permalink) Old Apr 24th, 11, 10:55 AM
Kurt
camsdad's Avatar
Re: 327 to 383
Might want to check and make sure it is a large journal block before you pursue this endeavor.
A 2 bolt block will be fine up to 500hp.
Not worth the expenses and extras to splay the block.
Kurt
1969RS 14yrs into it.
383CID Lives
200R4 Trans, 3:42 Posi 12 Bolt Ready
Cold ones in the fridge. Dam, there gone. BRB
Getting closer to my goal.
camsdad is offline
post #6 of 11 (permalink) Old Apr 24th, 11, 11:17 AM
Re: 327 to 383
I thought I remember hearing that a lot more clearance grinding is needed with a 327 block. The 350 block was opened up some for the larger 3.48 stroke? As mentioned make sure it's a large journal block.
markw is offline
post #7 of 11 (permalink) Old Apr 24th, 11, 02:02 PM
darrell
Re: 327 to 383
so true on all statements--i would use a 350 block the cost is gonna be the same --but if your persistant -you gotta know if its a large journal or not-i would recommend scat for a crank--KB for pistons--and a great machine shop for balancing which is critical(i prefer this over a rotating assy that say they are balanced--i have built plenty of 383s and optimistic 500hp is perty easy--dont forget to chek rod to cam clearance
97Z4C is offline
post #8 of 11 (permalink) Old Apr 24th, 11, 09:14 PM
Re: 327 to 383
383 stroker kits are available for the small journal 327 as well. http://www.speedomotive.com/ps-30-8-...roker-kit.aspx
BPOS is offline
post #9 of 11 (permalink) Old Apr 24th, 11, 11:52 PM
Kurt
camsdad's Avatar
Re: 327 to 383
There ya go!
Kurt
383CID Lives
camsdad is offline
post #10 of 11 (permalink) Old Apr 27th, 11, 10:15 AM
Re: 327 to 383
The 2.30" Main bearings of a 327 block is a NO NO for 3.75" stroke.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
hhott71 is offline
post #11 of 11 (permalink) Old Apr 27th, 11, 06:38 PM
harvey
Re: 327 to 383
i have a 68 327 large jounel block sitting in my basement can't wait to use it but nobody can tell me realy the year is i know 68 and above i differeny know it's a 327
pink panther is offline
