Need accelerator spring bracket - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 24th, 11, 07:25 PM Thread Starter
joel
Does anyone have any info on where I could find an original retainer bracket which holds the rear loop of the throttle return spring in place. This bracket mounts on top of the coil bracket and is needed for a 1967 small block(327) with rochester 4bbl carb. If I understand correctly, this was only used on the '67 models. 1968 used a different version. An aftermarket in the correct style would also work for me. I've searched the usual parts books (Ground Up, Rick's, Classic, etc.) and cant seem to find one.(Classic does list the style for 1968). Or should I otherwise use a coil bracket with a tab and hole off the side? In that case, any problems using a coil bracket set to an angle for cowl hoods (which is required for clearance on cowl hood air cleaner set-ups)? This is the only type coil bracket I've seen with the side tab for first gens. Any other reasonable suggestions for securing the rear end of this throttle spring? Thanks much in advance--Joel
jigsaw is offline
post #2 of 5 (permalink) Old Apr 24th, 11, 07:51 PM
Chad
67 Plum's Avatar
Re: need accelerator spring bracket
You could make one. Its just a thin piece of metal with 2 holes in it.Even if its not perfect you can"t see it with the air cleaner on.
67 Plum is offline
post #3 of 5 (permalink) Old Apr 24th, 11, 07:59 PM
I think he means like this one?
Sent from my iPhone using Autoguide
Melrose RS is offline
post #4 of 5 (permalink) Old Apr 25th, 11, 06:39 AM
Re: Need accelerator spring bracket
I made mine but recently remeber seeing someone sold it just can't remember who. So easy to make not worth ordering anyway.
1969 Camaro SS
350/300 M20
12 Bolt 3:73 Posi
Myfirst 69SS is offline
post #5 of 5 (permalink) Old Apr 25th, 11, 03:53 PM Thread Starter
joel
Tom,
Yes, thats the type I'm looking for. Now where can I find one? (original or aftermarket would work.) Thanks for the picture!
Joel
jigsaw is offline
