Comp Cams 3 piece timing cover ? - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 27th, 11, 09:34 AM Thread Starter
Trev
madcarson's Avatar
Hi
Is anyone running this cover witha 1 piece Felpro pan gasket ? It looks to me like it barely seals on the cover to pan area ?
69 Resto MOD
383
madcarson is offline
post #2 of 4 (permalink) Old Apr 27th, 11, 11:52 AM
Re: Comp Cams 3 piece timing cover ?
If its the same as the Cloyes cover, they will work with a one piece oil pan gasket.
I have a cloyes and one piece felpro blue gasket.
TC # 349
zdld17 is offline
post #3 of 4 (permalink) Old Apr 27th, 11, 02:14 PM
I ran this combo on a big block and it worked fine. Don't know about the small block.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #4 of 4 (permalink) Old Apr 28th, 11, 04:42 PM Thread Starter
Trev
madcarson's Avatar
I oiled the gear drive then put cover fronts on and oil ran out the btm between pan and gasket ? Moroso 7 qrt pan and it worked before with the Cloyes cover that uses a wide frt gasket ! So now what I'm confused ?
69 Resto MOD
383
