Targetmaster Engine - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 27th, 11, 03:33 PM Thread Starter
Targetmaster Engine
Trying to find out more about my engine. On the front left near valve cover are these numbers..... MB15353. Does anyone know anymore about this engine....who made it? hp? anything? It does have stamped in it Mexico"
manofsteel1 is offline
post #2 of 3 (permalink) Old Apr 27th, 11, 04:00 PM
Vintage 68's Avatar
Wink Re: Targetmaster Engine`
It's a GM 'TargetMaster/GoodWrench' 350/260hp universal replacement small block - w/dual dipstick casting provision.
The block was cast and assembled in the Toluca, Mexico Engine Assembly plant.
Internal parts were originally;
Block = part # 10066034, casting # 10066036 - 2 piece rear main seal 4 bolt main
Crankshaft = # 3932444 - Nodular Iron 1985 and older flywheel bolt pattern.
Powdered Metal Connecting rods = # 10108688
Cast Aluminum Pistons = #12514101
G.M. High Volume Pump Oil Pump = part # 12555284
Hydraulic Flat tappet Camshaft = #14088839 - Intake Lift .383" / Exhaust Lift .401" - Intake Duration @ .050" = 194 / Exhaust Duration @.050" = 202 - Lobe Seperation = 112 deg.
Head casting changed over years, but most likely '993 units ...
Hope this helps some
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 3 (permalink) Old Apr 28th, 11, 05:33 AM
Had some of these motors, they will get you down the road. I have had them torn down to find stuff like .030 and .040 pistons in differant holes.
I have had guys tell me that others have found differant size crank throws. But as I said, they will get you down the road.
TC # 349
zdld17 is offline
