Backfire through CARB??? - Team Camaro Tech
post #1 of 10 (permalink) Old Apr 28th, 11, 07:50 AM Thread Starter
Ty
Hi there,
Im new here, as i just bought a 69 Camaro.
My car has a Merlin 509 BB, with a Holley Carb. I just started driving it. Now... I noticed when I shut the car off, there is a loud backfire, a puff of black smoke out of the cowell induction... obviously out from the K&N air cleaner.
It doesnt happen all the time. I noticed the same noise and puff on a start up... i think cuz it was cold...
I sounds like a backfire. what is the cause for this? Is this a bad sign for things to come?
Please help me....
wrxninja is offline
post #2 of 10 (permalink) Old Apr 28th, 11, 12:27 PM
Terry
Re: Backfire through CARB???
Poor ignition timing can cause carburetor popping when the intakes valves are not properly closed before fuel combustion.
Both optimists and pessimists contribute to society. The optimist invents the automobile, the pessimist seat belts, head rests, disc brakes, and air bags.
IRON MAN is offline
post #3 of 10 (permalink) Old Apr 28th, 11, 01:18 PM
Wes
To be clear, it pops through the carb 'after' the ignition is turned off?
Straight-line-69 is offline
post #4 of 10 (permalink) Old Apr 28th, 11, 01:48 PM
George
Sounds like timing might be a little high.If you are running an automatic trans you can try putting in gear holding the brake and shutting engine off just dont forget to put back in park or if manual trans ease out on clutch to put load on engine and shut it off. hope you can find the problem.
z28station is offline
post #5 of 10 (permalink) Old Apr 28th, 11, 01:52 PM
Ron
You can get Run On & Carb Popping if the Throttle Plates are not closing or not adjusted properly when shutting down.
This was my 70 1/2 Z28
Z15CAM is offline
post #6 of 10 (permalink) Old Apr 28th, 11, 04:01 PM
Dan Ensign
Nobody else has said it so I'm gonna, we need pics. How does it run other than that, also check that there isn't any fuel leaking down the carb from high float levels. Sounds like a timing issue though.
Dan E.
69 SS396 4spd. 4.10posi. x66 coupe
Dan E. is offline
post #7 of 10 (permalink) Old Apr 28th, 11, 09:26 PM
Wes
I don't see how it's a timing issue if the popping happens "after" the ignition is turned off.
post #8 of 10 (permalink) Old Apr 28th, 11, 10:27 PM
AJ
You should put a light on it to see what the timing is doing...
BTW, I had the wires wrong on my cap once, wouldn't run or idle, flames out of the carb run on etc... Moved the wires back on the cap, fixed it.
If it's retarded the plugs/cylinders will be hot enough to pre ignite the fuel.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #9 of 10 (permalink) Old May 1st, 11, 04:49 PM
WrenchingAce
Sounds like a bad Magnetic Pickup to me. I'll bet it has an MSD Distributor...if it does then you should pull the dist cap off and take a look inside at the magnetic pickup assembly...it's probably all corroded.
speedfreak2 is offline
post #10 of 10 (permalink) Old May 2nd, 11, 05:01 AM
darrell
all good points- i would set timing first -re set idle mixture screws 2nd with vacuam gauge and chek for fuel dripping thru ventures on carb
97Z4C is offline
