Lucky day?? - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 29th, 11, 02:31 PM Thread Starter
Hector
Lucky day??
Well went outside started the car and forgot the keys to the trunk.. Went back inside grab a cup of coffee and started back out.. As I walked to the car..all of a sudden it started to smoke and noticed something pooling under car... Hobbled over and shut car off.. Opened the hood.. And discovered that the oil plressure line had split..... I was lucky I was on my way out because in less than 15 seconds it pumped out about 1/2 quart.. That was addressed.. .. So backed it into my driveway turned the wheel and ot out to see if I had enough room to finish my spring swap.. When all of a sudden the car starts to stall and I see gas pouring out the bottom.... Car stalls I open the hood and guess what...the fuel line came off the fuel pump...
Also noticed that the shop also didn't use the correct motor mount bolts...(the bolts that hold the motor mount to the frame stands) They were to long so the used a lug nut on each bolt as as spacers
Two major catastrophe avoid by shear luck...the shop I paid to do the engine swap really half azz it...
68 Camaro Coup, BBC ,2457 headers, th400 , ford 9", Hotchkiss connectors,
Speedjester is offline
post #2 of 5 (permalink) Old Apr 29th, 11, 03:21 PM
Fred
Re: Lucky day??
Sounds like you can and should do your own swaps.
128.79mph 1.428 60'
Fred Ficarra is offline
post #3 of 5 (permalink) Old Apr 29th, 11, 03:27 PM
Re: Lucky day??
Yikes!! Scary stuff.
Melrose RS is offline
post #4 of 5 (permalink) Old Apr 29th, 11, 03:34 PM Thread Starter
Hector
Re: Lucky day??
Fred if I wasn't wearing this leg immobilizer.. I would have done it myself.. But not being able to bend your leg and crutches make things difficult
You should have seen me swapping springs yesterday.. Got all my tools Placed them on the ground and sat on a crate with one leg extended straight... Once I was down I just dragged myself around the car...after everything was done had wife and step daughter help me up..
post #5 of 5 (permalink) Old Apr 29th, 11, 03:36 PM Thread Starter
Hector
Re: Lucky day??
Melrose I have a ton of stuff I need to address before I can actually take this car on a nice ride.....
I was really lucky today...
