valve cover leak - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 30th, 11, 06:47 PM Thread Starter
Question valve cover leak
I have center bolt valve covers on my 383 with afr aluminum heads and cant seem to keep these from leaking---anyone have a soloution????
69huggero is offline
post #2 of 4 (permalink) Old Apr 30th, 11, 10:00 PM
darrell
Re: valve cover leak
1st make sure a good breather-pcv valve --the guides for the bolts in the valve cover are bottoming out and not letting gasket to make full contact
97Z4C is offline
post #3 of 4 (permalink) Old May 1st, 11, 02:53 PM Thread Starter
So your thinking the guides are bottoming out and not letting the gaskets seal--like the guides are to long?
post #4 of 4 (permalink) Old May 3rd, 11, 09:37 AM
Brandon
What kind of gaskets are u using? Cork Gaskets and sealant....we never have problems.
71 Chevelle 496 Stroker Hyd Roller 675HP, TH400 3500 Stall, 3.73 12 Bolt.
ATK HP ENGINES
Custom Built Street-Strip-Racing Engines
Notalent is offline
