Big Block - Team Camaro Tech
post #1 of 9 (permalink) Old May 1st, 11, 07:46 AM Thread Starter
Big Block
Let me start by saying I don't know a thing about motors. I was looking for a 427 to put in a 67 camaro but they are out of my price range.I found a good deal on a 396 so what I want to know is if I put a 427 decal on the air cleaner can you tell the difference, I want it to look like a big blook 427.Will it look the same or to I have to keep looking for a 427. Thank you.
oldcam is offline
post #2 of 9 (permalink) Old May 1st, 11, 07:56 AM
JimmyC's Avatar
Re: Big Block
No external difference. Block ID numbers only will vary. You can actually make the 396 in to a 427 with a oversize bore lot of old drag racers use to do that.
69 ZZ427 RS resto-mod in progress.
Build Pics --->
69 X77 Z28 406 TH400.
69 Pre X RS Z28 in boxes.
67 Chevelle 496 TH400.
64 Nova 396 TH350.
Gold Member #1164
JimmyC is offline
post #3 of 9 (permalink) Old May 1st, 11, 08:09 AM
jeff
Re: Big Block
Get a 454 and do the same thing, easier to find. They all look the same on the outside.
jkuro is offline
post #4 of 9 (permalink) Old May 1st, 11, 08:35 AM Thread Starter
Re: Big Block
Thanks for the help I just want it to have the right look.
oldcam is offline
post #5 of 9 (permalink) Old May 1st, 11, 04:10 PM
ern
ern
Re: Big Block
I did just that, 454 block,eagle ros . K.b. Pistons, and 427 crank,aluminum heads , comp cam and air gap and proform carb. Just started it today,it sounds great,
ern is offline
post #6 of 9 (permalink) Old May 1st, 11, 05:27 PM
george
Re: Big Block
The 454 block better be a Mark IV..the gen 5 and 6 would be a dead give away.By all means rebadge the 396 to 427.Only you will know as they are both internally balanced.If you go mark IV 454..keep enquiring fingers away from the backside of your harmonic dampner unless you balanced internally with Mallory metal.
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline
post #7 of 9 (permalink) Old May 4th, 11, 05:20 PM Thread Starter
Re: Big Block
Next question, on some big blocks the alternator is on the passanger side I want it on the driver side is that something easy to change.
oldcam is offline
post #8 of 9 (permalink) Old May 4th, 11, 09:28 PM
Banned
Bethanne
Nashville Beth's Avatar
Re: Big Block
If the car was originally a smallblock there is a lot of stuff to change - it gets expensive !
Nashville Beth is offline
post #9 of 9 (permalink) Old May 4th, 11, 09:51 PM
Re: Big Block
You will need to use a short water pump and all the related brackets for the same. In '67, that is the combination they used. This will put the alternator on the drivers side. In '69 they switched to the long water pump and the alternator on the passenger side. BB brackets for the short pump will be harder to find, but they are out there. It's cost you some $$ over the long pump brackets, though. There are a bunch of differences between SB and BB Camaros. If you are wanting it to look correct, it'll cost you some more $$. Do a search here. There is plenty of discussion on butting BBs in cars that didn't originally come with them.
buenymayor is offline
