PF25 or 35 for BBC - Team Camaro Tech
post #1 of 7 (permalink) Old May 1st, 11, 09:03 AM Thread Starter
Jeff Johnson
PF25 or 35 for BBC
i have a 68 camaro 396 and bought a AC Delco PF25 oil filter. I went to change my filter and found that a PF35 was installed. What was correct for the 68 camaro BBC?
jeffjohns is offline
post #2 of 7 (permalink) Old May 1st, 11, 02:07 PM
Hector
Re: PF25 or 35 for BBC
More capacity in the pf35..... Now it's the pf1218...
Pf25 half quart capacity... The pf35 one quart capacity.. From what I have read the pf35 is being replaced by the pf1218..
68 Camaro Coup, BBC ,2457 headers, th400 , ford 9", Hotchkiss connectors,
Speedjester is offline
post #3 of 7 (permalink) Old May 1st, 11, 03:32 PM
Long filter is correct, but, short filter may have toi be used if headers are installed.
Either filter you use, fill it with oil and lube the gasket before installing - cuts down on purging air from the filter at start-up.
post #4 of 7 (permalink) Old May 2nd, 11, 06:02 AM
greg
If you have the extra room try the Wix 51794 2 quart truck filter.
docwilcar is offline
post #5 of 7 (permalink) Old May 2nd, 11, 06:14 AM
Jeff
yellow69RS's Avatar
I doubt that anyone of us has ground clearance for that in a first gen. Better take some measurements before you go to parts store looking for one of those.
Jeff
yellow69RS is offline
post #6 of 7 (permalink) Old May 2nd, 11, 06:22 AM Thread Starter
Jeff Johnson
Thanks guys, i will go with the PF35.
post #7 of 7 (permalink) Old May 2nd, 11, 06:35 PM
jeff
Ac pf35 = wix 51061
ac pf25 = wix 51069
jkuro is online now
