head bolt question - Team Camaro Tech
post #1 of 5 (permalink) Old May 2nd, 11, 06:29 PM Thread Starter
head bolt question
Are there supposed to be washers under the head bolts?
I see on some sites where the sell head bolts they show washers in the pictures.
kmz68bird is offline
post #2 of 5 (permalink) Old May 2nd, 11, 06:40 PM
Chuck
Re: head bolt question
Factory assembled engines are not equipped with washers. (OEM engineers obviously did not take our kind of activity into account.) ARP headbolts for Chevy applications are sold with washers included. They are effective at avoiding galling in the area of contact between the head of the bolt and the cylinder head during torquing and they help the assembler achieve consistent torque pressures. They are especially valuable on aluminum heads. Washers are a plus in any application that is anticipated to have the heads removed frequently.
c
cnorton7311 is offline
post #3 of 5 (permalink) Old May 2nd, 11, 07:59 PM
Hector
Are they arp washers faced??
68 Camaro Coup, BBC ,2457 headers, th400 , ford 9", Hotchkiss connectors,
Speedjester is offline
post #4 of 5 (permalink) Old May 3rd, 11, 07:04 AM
Chuck
If I understand your question correctly, the answer is, yes, the surface faces are parallel ground. I buy those washers in a variety of sizes in bulk packages from ARP for that very reason.
post #5 of 5 (permalink) Old May 3rd, 11, 08:14 AM
Mickey
Moonpie's Avatar
I would use washers only on aluminum heads for anti-galling purposes. They are not needed on iron heads.
Moonpie is offline
