Storage start-up,Zinc 4 oil? - Team Camaro Tech
post #1 of 4 (permalink) Old May 2nd, 11, 08:27 PM Thread Starter
Hello everyone, my 67 camaro with 6 cylinder has been sitting stored for 15 plus years and not touched. When I get the engine running I heard todays oil is not compatible with the bearings due to zinc content and bearing failure will result . How true is this and what is the cure. Thanks in advance as I know I need alot of things to check before startup
676popper is offline
post #2 of 4 (permalink) Old May 2nd, 11, 09:35 PM
Banned
Bethanne
Nashville Beth's Avatar
Re: Storage start-up,Zinc 4 oil?
Zinc levels have been reduced but the cam in your 6 cylinder does not have enough lift to damage a lobe or lifter.
High spring pressures and reduced zinc can cause failure of cam lobes and lifters.
You don't have to worry about that.
Nashville Beth is offline
post #3 of 4 (permalink) Old May 3rd, 11, 12:21 AM
T-Bone's Avatar
Like Bethanne said, a good broken-in motor doesn't need lots of high-pressure additives, especially your good old straight six. If you were doing a fresh start on a flat tappet race motor, that's another story. But you will be A-OK with any oil.
Good luck and keep your 6-cylinder a 6-cylinder if you can!
T-Bone is offline
post #4 of 4 (permalink) Old May 3rd, 11, 08:09 AM Thread Starter
Thanks for the reply, Can't wait to get the car up and running. The car is in good shape as only has 58,000 miles.
