Re: aluminum valve cover clearance
I've seen this before. The v/c's have a lip around them as a stiffener. Use thicker gaskets and you should be fine. If you cannot find them, glue two sets together with high temp silicone gasket maker. I still prefer the cork v/c gaskets. I use 6-8 dabs of silicone on the valve cover side and none on the head side. That way the gasket comes off with the valve cover and not stuck to the head.
Russ (RJ)
The Garlic Capital, Gilroy,CA
(sold June 15,2014) 1968 RS convertible that is not quite stock
