zz4 crate engine - Team Camaro Tech
post #1 of 15 (permalink) Old May 6th, 11, 03:17 PM Thread Starter
zz4 crate engine
Thinking about buying a zz4 from GM Performance Parts. Anyone have any experiences with it? Looking for your thoughts and opinions.
Thanks,
psm67 is offline
post #2 of 15 (permalink) Old May 6th, 11, 06:33 PM
joseph l clance
joe clance's Avatar
Re: zz4 crate engine
Have one in my camaro for almost eight years. improvements ive added over the years are: eldlebrock, EPS manifold (nice improvemnet), 600cfm holley Dp (stay away from big CFM carbs), thumper cam (if you want it to rock) along with big tube headers (needed for the "D" exhaust ports).
its never let me down.
69 X-44 base coupe, ZZ4, 16lb nodular flywheel, Center force DF clutch + PP, Holley 600DP, Hooker super comp 1 3/4 ceramics, 2.5" dual exhaust w/ X-pipe, flowmaster 40 series mufflers.
joe clance is offline
post #3 of 15 (permalink) Old May 6th, 11, 07:59 PM Thread Starter
Were you satisfied with the performance it its stock form?
psm67 is offline
post #4 of 15 (permalink) Old May 6th, 11, 08:00 PM Thread Starter
How long did you have it before you felt the need to modify?
psm67 is offline
post #5 of 15 (permalink) Old May 7th, 11, 04:30 PM
joseph l clance
joe clance's Avatar
about 5 years before i cracked it open. while getting a valve job i decided to pump it up a bit.
its fine right out of the box. 350/390 hp/tq gives you a good feeling
joe c
post #6 of 15 (permalink) Old May 7th, 11, 06:09 PM
Banned
Alan
98blackburb's Avatar
I had a ZZ3 (1st Gen ZZ) in my 1st 69 and loved it,hammered it,cruised it.....I had a 10 bolt open 2.73 with a built PowerGlide w/2500 stall...... Nobody believed it until I took them for a ride going 50MPH ...hit it,burn rubber and downshift all at the same time.
98blackburb is offline
post #7 of 15 (permalink) Old May 7th, 11, 07:03 PM
Kevin
I've got the 355 hp ZZ/4 350. I was a little disappointed when I saw it's made in Mexico, but I must admit it runs good. I've done a cam swap in it and it's even better now.
kcart55 is offline
post #8 of 15 (permalink) Old May 8th, 11, 03:52 PM Thread Starter
I was also considering the fast burn 385. I like the hp number but would prefer more torque. Still not sure wich way to go.
psm67 is offline
post #9 of 15 (permalink) Old May 8th, 11, 08:06 PM
Edm
Ed
I have had mine for a year now and have been perfectly happy with it. Holley 650 with 70 and 72 jets, runs perfect. I think its a great deal for the price and plenty of power for the street. If you plan on racing it will be very reliable but a little under powered. When I get board I might do a head and cam swap just for the fun of it but for now it is fine.
Edm is offline
post #10 of 15 (permalink) Old May 8th, 11, 09:00 PM
Where did you see that it was made in Mexi?
i thought the base 260hp and 290hp version were made south of the border, but the higher end crates----zz383, ramjet, fastburn, 350HO etc. are made by 2 gm employees in michigan?
puff puff is offline
post #11 of 15 (permalink) Old May 9th, 11, 06:15 AM
DJ
I had the same questions last fall for my '68. I ended up getting the FB385 and installing the LT4 cam and 1.6 rockers. I couldn't be happier. Very smooth running at the low end and is a beast at the high end.
- Completed March 2011, black w/ bumblebee stripe, RS/SS, FB385 w/LT4 cam, TKO-600, Moser 12-bolt
djfire07 is offline
post #12 of 15 (permalink) Old May 9th, 11, 06:31 AM
DJ
Oh and ... Buenos días, amigos!
djfire07 is offline
post #13 of 15 (permalink) Old May 9th, 11, 09:00 AM
Brandon
The block was made in Mexico, not the engine. They are great engines. You can get more bang for your $ through a reputable builder. Let me know if I can help with anything. ;-)
71 Chevelle 496 Stroker Hyd Roller 675HP, TH400 3500 Stall, 3.73 12 Bolt.
ATK HP ENGINES
Custom Built Street-Strip-Racing Engines
Notalent is offline
post #14 of 15 (permalink) Old May 11th, 11, 07:30 PM Thread Starter
Anyone have any header recommendations. Manufacture and size.
psm67 is offline
post #15 of 15 (permalink) Old May 11th, 11, 10:20 PM
.gearhead.'s Avatar
I had a ZZ4 for about a year. It was a very reliable drive anywhere car that went 12.20's all day.
Then: N/A, 436 ci, Stock Block, Track 1's, Stock Suspension, Ranchos, 3250 lbs... 1.33 60 ft / 9.69 @ 138 mph
Now: Boost...
.gearhead. is offline
