67-69 Dynatech headers - Team Camaro Tech
post #1 of 40 (permalink) Old Jan 28th, 12, 01:44 PM Thread Starter
Just got my Dynatech headers (part# 740-11210) today and unboxed them...figured i'd show you guys all the contents and the quality of the headers if anyone is considering buying them...overall i think for $400 you really can't beat them and as many say pictures say a thousand words!
2.5" reducers, header bolts, header gaskets, alternator spacer?, flange adapters and instructions.
Passenger side header
Driver side header #1
Driver side header #2
Header flange
3" Collector
Overall i'm impressed by the quality of these headers for the price. I like the fact that the flange is one solid piece. They look and feel heavy duty.
Now i know stepped headers are a myth but the real reason why i think they step the headers is to get the angles they are looking for to wrap the headers around the steering box and overall fitment.
Should be installing them soon and see if they clear my rack and pinion setup. Cheers!
Current build summary: 69' Camaro, 383 stroker, 750 Holley DPer, DSE subframe connectors, flaming river rack and pinion, 700R4, 8.8" rearend w/ 3.73's
383bowtie is offline
post #2 of 40 (permalink) Old Jan 28th, 12, 02:09 PM
Andrew
Andrew69's Avatar
Re: 67-69 Dynatech headers
Those really do look good! The thick flanges just say quality.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #3 of 40 (permalink) Old Jan 28th, 12, 03:03 PM
My advice, pitch the gaskets that go between the flange and the head - buy a set of Percy's and be done with it - the gaskets that came with them didn't last a week for me before they were leaking.
69 Pace Car and 69 Hard top
srode is offline
post #4 of 40 (permalink) Old Jan 28th, 12, 04:05 PM Thread Starter
read that on here as well and ordered them with the headers.
post #5 of 40 (permalink) Old Jan 28th, 12, 04:24 PM
Very nice looking set of headers. One concern about driver side header is #1 inner bolt location & #5 outer bolt being accessible for removing &/or tightening. I have a set of Hooker Competition with 3 or so which are a challenge on my sbc.
Tom Sholl
Shollt is offline
post #6 of 40 (permalink) Old Jan 28th, 12, 04:38 PM
Steiner
No question they are the deal of the century when it comes to small block headers. Even on the larger version all the bolts are easy to get to even with 7/16" heads. The back ones can be tightened with a socket wrench which makes you wonder why all makers don't drop the back tubes straight down like that. They do seem to have screwed the pooch with the large ones now since the latest design doesn't fit with a factory sized steering box.
BTW, the spacer is used when running the factory power steering pump bracket.
'69 Camaro
500hp/538lbft
Steiner is offline
post #7 of 40 (permalink) Old Jan 28th, 12, 06:11 PM
67 Camaros Rock
Joe Harrison's Avatar
are those collectors a ball socket type....they appear like them but don't seem to have as much? How is the fit of the collectors to the header and flange...does it slip over some and then seal with a gasket at the collector flange? Can you show a pic of this together...obviously not tightened up don't want you to mess up your gaskets.
-Mark Donahue
My 67 Camaro Time Line
Joe Harrison is offline
post #8 of 40 (permalink) Old Jan 28th, 12, 07:36 PM
Steiner
It uses a reusable graphite type beveled donut gasket on the collector and the reducer is a flare/socket.
'69 Camaro
500hp/538lbft
Steiner is offline
post #9 of 40 (permalink) Old Jan 28th, 12, 08:40 PM Thread Starter
the graphite rings slide over the collector and is the flare/socket mating surface...the reducer goes over that assembly...the four bolt flange slides over the reducer and tightens everything down
post #10 of 40 (permalink) Old Jan 28th, 12, 08:51 PM Thread Starter
im still thinking about sending them back because it looks like the #1 tube got damaged during shipping and may have cut through the coating...sucks
post #11 of 40 (permalink) Old Jan 28th, 12, 09:17 PM
67 Camaros Rock
This setup should be a leak free connection then, more like a factory connection....everyone agree
If this is the case these could be on my list as a purchase.
-Mark Donahue
post #12 of 40 (permalink) Old Jan 29th, 12, 05:28 AM
No problems with leaks on mine, they seal tight with the donut!
Mine arrived in perfect condition, that scratch while not bad is less than I would accept, I'd be trying to swap them for a replacement set too.
srode is offline
post #13 of 40 (permalink) Old Jan 29th, 12, 07:50 AM Thread Starter
yep calling Jegs today...brand new headers should be brand new!
post #14 of 40 (permalink) Old Jan 31st, 12, 07:19 PM Thread Starter
have to say im impressed with Jegs customer service on this...Fedex came to my house and picked up the package to send back to Jegs...didnt have to do anything but put it back out on the porch! no shipping charges either
post #15 of 40 (permalink) Old Feb 1st, 12, 12:02 AM
67 Camaros Rock
I love these headers I want to see some pics of them installed and see the fit around the steering box. Wonder if you will have to "clearance" them at all there?
-Mark Donahue
