510 not getting oil pressure - Team Camaro Tech
post #1 of 9 (permalink) Old Sep 18th, 12, 03:29 PM Thread Starter
vern
Hello,
I have newly rebuilt 454 bored out to a 510. Im running MSD pro billet distributor. I filled the oil and primed the oil pump. Here is the problem.....
I am not getting any oil pressure with the distributor installed. I took the valve covers off and no oil is being pushed up the rods. With the motor running.... I put the oil pump priming tool back in and get oil right away.... ANY IDEAS?????
vstaving is offline
post #2 of 9 (permalink) Old Sep 18th, 12, 08:04 PM
Tom P's Avatar
Re: 510 not getting oil pressure
almost sounds like the distributor is not seating properly into the oil pump shaft. Compare the length of your priming tool to the dizzy when fully seated. Is it the slip collar MSD?
67 new build alum. 406 | 69 RS/SS 496 631 HP / 618 TQ | 73 Z28 Survivor 36k miles | 89 IROC Z 2500 miles | 02 SS 35th Anniv. LE 645 miles |11 SS Berger 550HP (1 of 25) | 14 ZL1 6M Recaros
Tom P is offline
post #3 of 9 (permalink) Old Sep 18th, 12, 11:54 PM
darrell
tom is on the right track but something seems mix matched--i am assuming its a standard block and bored and stroked to get 510- would bet on wrong oil pump shaft
97Z4C is offline
post #4 of 9 (permalink) Old Sep 19th, 12, 01:27 AM
Steiner
Just try to twist the rotor with the dizzy in. That'll tell you....
'69 Camaro
500hp/538lbft
Steiner is offline
post #5 of 9 (permalink) Old Sep 19th, 12, 04:04 AM
My guess is the oil band on the dist. is not lined up with the lifter passage .
ssdoug is offline
post #6 of 9 (permalink) Old Sep 19th, 12, 04:39 AM
I suggest checking the diameter of the housing at the oil band between the two items.
I believe MSD uses O-rings for sealing the oil band, could be another brand, I'm thinking.
post #7 of 9 (permalink) Old Sep 19th, 12, 06:35 AM Thread Starter
vern
Hey thanks guys. Ill check the length of the priming tool and dizzy.
vstaving is offline
post #8 of 9 (permalink) Old Sep 19th, 12, 07:44 PM Thread Starter
vern
YEP, that was it the dizzy was set too short. I adjusted the upper ring and it fell right in.
vstaving is offline
post #9 of 9 (permalink) Old Sep 20th, 12, 01:01 PM
Tom P's Avatar
Glad to hear it was an easy fix
Tom P is offline
