67 350 PCV help - Team Camaro Tech
post #1 of 17 (permalink) Old Sep 19th, 12, 09:17 PM Thread Starter
Rich
67 350 PCV help
I know that its been covered a ton and I think I have a good understanding on what should be on my car for PCV setup but I'm not sure what happened to my car and where to go.
Car is a 67, SS 350 4spd. There are no holes in the valve covers and they are original. There are no holes in the filler tube but there is a breather on the end of it. In the back of the block were the rear tube/pvc should be I have a hole, it is wide open with nothing in it. I clean out the junk that was in it and it goes down about 3 to 4 inches to what looks like metal, in the front (going towards the front of the car) of the hole there is a small circular hole about an 1 1/2".
The engine runs great and has been for over 20yrs like this but I'm trying to correct things that are wrong with it. I'm not sure if there is a plug at the bottom of the hole or what happened. Is this normal? I assume that I do not have a PCV valve installed somewhere else, the vacuum on the carb was capped off.
Any help would be appreciated. I want to keep the car as original as possible but I also want to make it better I have no intention of selling it as it has a lot of meaning to me so making it drive good is the big thing. I have thought about buying some new valve covers and installing a PCV valve in there.
Thanks,
Rich
H20cooled is offline
post #2 of 17 (permalink) Old Sep 19th, 12, 09:47 PM
Roger
rogerh's Avatar
Re: 67 350 PCV help
Welcome to the site Rich. If you have the original Q-jet carb there should be, I believe a 3/8" vac on the front of the carb. The PCV is installed about 2 to 3 inches from where it come out at the rear of the block. The hose then goes around the right side of the carb and goes into the front of the carb near the base.
Below is a pic of that hose and you can just see the PCV valve at the rear of the right valve cover.
Roger
Name:	PVC hoseJPG.jpg
rogerh is online now
post #3 of 17 (permalink) Old Sep 19th, 12, 09:52 PM
Steiner
Re: 67 350 PCV help
350SS still used the road draft setup without PCV. You can convert it using parts for other models though. Just need the oil filler tube made for screw in PCV and the screw in PCV. Also there is an air fitting that is expensive BUT another option that was used on some vehicles (Chevelle maybe?) is a small canister with nipple that plugs into the hole (where the draft tube goes) that can then be connected to the air cleaner for your fresh air intake. Some people just get a grommet and PCV to install right in the old road draft tube opening and use the stock oil filler setup as the air intake.
http://www.rickscamaros.com/catalogs...del_id=1&q=pcv
Here's a good thread that may help.
http://www.jalopyjournal.com/forum/s...d.php?t=151629
'69 Camaro
500hp/538lbft
Steiner is offline
post #4 of 17 (permalink) Old Sep 19th, 12, 09:52 PM Thread Starter
Rich
Re: 67 350 PCV help
Thank you! I do have the a Q-jet carb but the vac line was capped off and no lines installed.
The question is would the car run with the hole in the rear of the block left wide open with nothing installed in it? I would think I would get some oil or vac lose without something in there.
Thanks,
Rich
post #5 of 17 (permalink) Old Sep 19th, 12, 10:13 PM
Roger
rogerh's Avatar
Re: 67 350 PCV help
Are you saying you don't have a cap over that hole that has a hose fitting on it at the rear of the block? That hole needs to be covered because I believe it would allow dirt and crap to get into the oil. I put everything back the way you see it in the picture.
Roger
post #6 of 17 (permalink) Old Sep 19th, 12, 10:17 PM Thread Starter
Rich
Re: 67 350 PCV help
there is nothing in the hole it had a bunch of debris and stuff in it that is why I was wondering.
Would it run if it was not capped off and left open? I have a plan for getting it set back up again, I'm just kind of dumbfounded that it was left open and still ran fine for over 20 yrs that we have owned it.
post #7 of 17 (permalink) Old Sep 19th, 12, 10:47 PM
Roger
rogerh's Avatar
Re: 67 350 PCV help
This is a page from the Asm manual on the Engine Ventilation System. It shows the cap you need. I wouldn't leave the hole open for any more dirt to get in the oil system. The engine should run fine but that dirt is not good at all on the engine. After you seal that hole I would change the oil and filter.
Roger
post #8 of 17 (permalink) Old Sep 20th, 12, 07:35 AM Thread Starter
Rich
Re: 67 350 PCV help
Roger- I'm going to connect up a PCV valve to it similar to what you have. Can you tell me what you have in the hole in the block to connect up to?
Thanks,
Rich
post #9 of 17 (permalink) Old Sep 20th, 12, 09:44 AM
Vintage 68's Avatar
Unhappy Re: 67 350 PCV help
Originally Posted by Steiner View Post
350SS still used the road draft setup without PCV. You can convert it using parts for other models though. Just need the oil filler tube made for screw in PCV and the screw in PCV. Also there is an air fitting that is expensive BUT another option that was used on some vehicles (Chevelle maybe?) is a small canister with nipple that plugs into the hole (where the draft tube goes) ...
Here's a good thread that may help. ...
WOW
How can so much miss-information be put in one thread
GM discontinued "Road Draft" tubes in 1962 - period ...
They were not allowed on vehicles after that year-model - period ...
All GM vehicles used some form of PCV after 1965 - period ...
That thread from 'jalopy-hack' is totally wrong on so many points to be any help to anyone and way off the chart on specifics ...
Good 'shade-tree' mechanical insight though
All 1967 Camaro's had one of two PCV systems on them from the factory.
It's been covered on many great threads on here in the past, such as - https://www.camaros.net/forums/showth...light=1967+PCV
And this OP's system directly - https://www.camaros.net/forums/showth...ight=Dixie+cup
Here's another past thread with great information on modifying the system with modern parts - https://www.camaros.net/forums/showth...light=1967+PCV
Carry on
1968 Convertible
Some trucks
Vintage 68 is offline
post #10 of 17 (permalink) Old Sep 20th, 12, 10:51 AM
George
Re: 67 350 PCV help
Rich,
You need what we call the "dixie cup" adapter, as shown in the AIM drawing, then two sizes of hose, along with the PCV valve and retention clip / bracket. Good luck on finding an original clip (if that's important to you), as the repops are not correct, and I too have been looking for a clip. I can only assume that your engine still has the "coffee can" oil seperator down inside the valley of the engine (below the intake manifold), or that engine should have been "toast" a long time ago due to the debris entering the engines lube system, etc.. PM me if you can't find an adapter.
67 RS Ragtop is offline
post #11 of 17 (permalink) Old Sep 20th, 12, 11:06 AM Thread Starter
Rich
Re: 67 350 PCV help
Originally Posted by 67 RS Ragtop View Post
Rich,
Thank you for the info. Is there any issues with installing a rubber grommet and a PCV valve and connecting it to the Q-jet while I try to find one of the dixie cup adapters?
Thanks,
Rich
post #12 of 17 (permalink) Old Sep 20th, 12, 06:11 PM
Steiner
Re: 67 350 PCV help
Originally Posted by Vintage 68 View Post
WOW
Whoops. Sorry to post bad information. I can only learn from what I read which is sometimes bad as well. Didn't mean to ruin anyone's day.
Either way, I don't think the PCV setups recommended were incorrect....or were they?
'69 Camaro
500hp/538lbft
Steiner is offline
post #13 of 17 (permalink) Old Sep 20th, 12, 08:35 PM
Roger
rogerh's Avatar
Re: 67 350 PCV help
Thanks,
Rich
Rich I stayed with the stock setup. Below is a pic before I got it cleaned up. This pic also shows the clip that holds the PCV valve. The taped up hole is for the distributor.
Roger
post #14 of 17 (permalink) Old Sep 20th, 12, 08:53 PM Thread Starter
Rich
Re: 67 350 PCV help
Roger
Roger- Thank you. Now I just need to find one of the Dixie Cup adapters.
Rich
post #15 of 17 (permalink) Old Sep 21st, 12, 09:45 AM
Vintage 68's Avatar
Re: 67 350 PCV help
The 'Hose Adapter'/Dixie-Cup units show up on eBain quite often.
I can usually find one on some old truck engine at the P-N-P wrecking yard places in a visit or two ...
The Corvette 'repoppers' are one of the best sources for many correct PCV system parts for F-Bodys
They tend to cater to folks that are trying to get the original look vs. the guys selling parts to the Camaro-Crowd - whom only seem to care about if it looks cool and shiny
Corvette places like ZIP and Paragon have a great parts selection to restore most systems - https://www.paragoncorvette.com/c-23...vent-tube.aspx
Paragon often has 'Dixie-Cups' available, but you have to call to check.
You could even go with the 63/64 SBC grommet and tube used on early 'vettes for a functional, but not quite stock system ...
1968 Convertible
Some trucks
