HOLLEY 4053 Carb - Team Camaro Tech
post #1 of 8 (permalink) Old May 8th, 14, 03:25 PM Thread Starter
kev
HOLLEY 4053 Carb
Have the original 4053 list carb for my 68Z. It has two broken ears on the baseplate. What other base plates from which carbs will fit this 780 cfm carb?
1969396 is offline
post #2 of 8 (permalink) Old May 8th, 14, 03:41 PM
Tim
Re: HOLLEY 4053 Carb
Do you want it to just be functional, or look correct? An early thin base 3310 should work (I have one here somewhere, will check) but I think the vacuum ports are not in the correct 4053 location. I'd suggest contacting Eric at Vintage Muscle Car Parts, he'll know exactly what looks right, and may be able to help you find one.
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Sold Clippinger Chevrolet. Raced at Lions in LA.
ZLP955 is offline
post #3 of 8 (permalink) Old May 8th, 14, 04:14 PM Thread Starter
kev
Thanks for the info. Some place to start.
1969396 is offline
post #4 of 8 (permalink) Old May 8th, 14, 05:19 PM
DjD
DjD's Avatar
I think the 4346 would work, it's also a vac sec 780 w/divorced choke. The only real difference I know of is the 4053 vent on the primary bowl.
Both 4053 and 4346 are still produced for over the counter at parts stores, you should be able to buy a new baseplate...
...Dennis
DjD is offline
post #5 of 8 (permalink) Old May 8th, 14, 06:37 PM Thread Starter
kev
Have not had any luck so far locating a source. Any ideas?
1969396 is offline
post #6 of 8 (permalink) Old May 8th, 14, 08:02 PM
DjD
DjD's Avatar
Try here... http://www.holley.com/CustomSpeedShop/
...Dennis
DjD is offline
post #7 of 8 (permalink) Old May 8th, 14, 08:41 PM
Tim
Those, and service replacements from the early 1970's onwards, have the thicker style of baseplate, but would be a good solution if the OP is not concerned over keeping original appearance.
ZLP955 is offline
post #8 of 8 (permalink) Old May 10th, 14, 10:16 AM
JohnZ's Avatar
Jerry MacNeish is a wizard when it comes to repair of broken Holley baseplates.
JohnZ
CRG
JohnZ is offline
