starter gear gets stuck in flywheel. - Team Camaro Tech
post #1 of 4 (permalink) Old May 10th, 14, 10:47 PM Thread Starter
Ronnie
so my starter gear just recently started getting stuck in the fly wheel. my car has been starting great every time an then i changed out my fuel system and drum brake rebuilds and first time i started it, it took a while cranking non stop for about 10 mins(mind you i did end up flooding it.....) finally it started and then it sounded like plastic broke off and now when i start it all it does it turn over maybe one time and then dead stop. ill look under and its stuck. i unstick it and then it doesnt turn over anymore. took the battery to autozone and it tested good with 70% charge. got a starter from o'reillys and installed it exactly like the last one was and went to start it, same thing, almost turned over and then dead. any ideas? i would appreciate it.
Ronnie.Sontag is offline
post #2 of 4 (permalink) Old May 11th, 14, 08:38 AM
Re: starter gear gets stuck in flywheel.
Externally charge the battery, clean all battery cable connections, both ends, and add a 0.020" shim under the starter nose to block.
Last thing you want is pinion being jammed in ring gear and starter motor still engaged.
Let's out a lot of smoke and smoke cannot be replaced.
Everett#2390 is online now
post #3 of 4 (permalink) Old May 11th, 14, 10:15 AM
Here you go....same way I do it.
http://youtu.be/r5a8kVUKht4
68 Camaro~LSx ~all motor
post #4 of 4 (permalink) Old May 12th, 14, 08:27 PM Thread Starter
Ronnie
thank you for that video and the advice! i have to do all this on the car itself but now i have an idea of what to do. ill try it and see what happens.
-Ronnie
