ZZ4 350 - which MSD distributor/box set-up to use? - Team Camaro Tech
post #1 of 8 (permalink) Old May 12th, 14, 09:47 AM Thread Starter
Hey guys -
I've officially given up on the stock HEI as I keep nuking the ignition module. So, it's time to upgrade. I'm think MSD. Anyone have experience with a particular model # in this application? WIth 6AL box? Any other advice from folks who have been through this?
Thx,
Nick
Heynow14 is offline
post #2 of 8 (permalink) Old May 12th, 14, 09:49 AM
Vega$69's Avatar
Re: ZZ4 350 - which MSD distributor/box set-up to use?
Don't need the box. Go with an MSD 8360 and Blaster Coil and you'll be good to go.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 8 (permalink) Old May 12th, 14, 10:48 AM
maybe figure out why the modules keep blowing before spending a lot of money on something that isn't any better and adds a ton of clutter.
using the heat conducting goop under the module?
distributor body getting a good ground?
using the good GM modules?
you don't plan sincerity.
novaderrik is offline
post #4 of 8 (permalink) Old May 12th, 14, 02:46 PM
feragotti
I kept the same dizzy and just upgraded to MSD cap rotor and Coil due to the dizzy having to have a melonized gear on the ZZ4. Never had any issues. But I don't think the dizzy is the issue. I would check power going to the HEI coil along with the ground coming off your wire harness.
feragotti is offline
post #5 of 8 (permalink) Old May 12th, 14, 05:48 PM
You better read about how MSD has gone down hill. Not much quality control these days besides metal that rusts. Made in China?
COPO is offline
post #6 of 8 (permalink) Old May 12th, 14, 08:34 PM
Rufas
Biggest reason HEI modules fail is the coil in cap coil layer shorting, and/or the carbon brush installed incorrectly.
dave ray is offline
post #7 of 8 (permalink) Old May 13th, 14, 03:54 AM
I eliminated my 6AL box and went with the Pertronix Ignitor III with integrated rev limiter and matching coil
Really nice piece
69' SS/RS X11 PRO-TOURING E-FORCE LS7, DSE Sub, T56 MAG, Recaro, Wilwood disc, Racepak IQ3S, SpeedTech TA/JRI CO's, Pro-Venom 250s, Forgeline CV3C 20/19 - SOLD
Sheck44 is offline
post #8 of 8 (permalink) Old May 13th, 14, 03:58 PM
Doug
If you want to use a box with the distributor get the MSD 6AL, part #6425 and the MSD Pro-Billet Street Distributor #8361. MSD recommends the Blaster 2 coil to use with the 6AL box. If you have had any milling done to your intake manifold you can use MSD #85561 with an adjustable slip collar.
Cdminter55 is offline
Tags
6al, distributor, hei, msd, zz4
