Mounting holes for engine frame mount - Team Camaro Tech
post #1 of 20 (permalink) Old May 14th, 14, 11:17 AM Thread Starter
Ove
I installed new engine frame brackets, and engine mounts for my new engine.
Now, when i'm trying to install the engine, the frame brackets sits way to far against the rear, theres no chance i can get the engine that deep in. It will stop by both the distributor and transmission crossmember. I am starting to think my mounting holes are in the wrong position.
Any ideas? If some of you have a picture of the mounting holes, that would be great
Ovelarsen2000 is offline
post #2 of 20 (permalink) Old May 14th, 14, 12:05 PM
Michael
Re: Mounting holes for engine frame mount
I think you need to post a picture of what you got.
I think the pozzi site shows how the frame mounts (both SB and BB) are bolted to the sub.
mahunt is offline
post #3 of 20 (permalink) Old May 14th, 14, 12:41 PM Thread Starter
Ove
Sent from my iPhone using Tapatalk
post #4 of 20 (permalink) Old May 14th, 14, 12:45 PM Thread Starter
Ove
post #5 of 20 (permalink) Old May 14th, 14, 12:57 PM
Ed
Your frame stands look right, what kind of engine mounts are you using? I think that's the problem.
freezined is offline
post #6 of 20 (permalink) Old May 14th, 14, 01:09 PM Thread Starter
Ove
It's prothane 7-504-bl
post #7 of 20 (permalink) Old May 14th, 14, 01:25 PM
Jon
You sure you don't have the stands switched side for side?
Jon N
dyno jonn is online now
post #8 of 20 (permalink) Old May 14th, 14, 01:41 PM Thread Starter
Ove
Yep, tried both. When switched over the engine came to much forward, also conflicting with the transmission crossmember... I realy don't know! The holes seems correct to me, i can only hope the engine mounts are wrong...
post #9 of 20 (permalink) Old May 14th, 14, 02:47 PM
Ed
I think it's your mounts but it's hard to tell from your pics. The mounts should lay against the block and yours look like they have some type of spacer or stand-off behind them.
Here's an idea of what the frame stands and mounts look like from Pozzi's great site.
http://pozziracing.com/camaro_engine.htm
post #10 of 20 (permalink) Old May 14th, 14, 02:56 PM Thread Starter
Ove
That's not spacers, the boltholes are elevated like that on the block. Also, i dont have any problems with the height, only lenghtwise.
post #11 of 20 (permalink) Old May 14th, 14, 03:39 PM
Ed
Sorry, those just looked too tall to me. If your crossmember is in are you jacking the tranny up to clear the crossmember or is the bellhousing hitting the floor? If you remove the distributor will the mounts line up? Are you using a HEI distributor?
It can be tight putting the engine in with distributor. If the tranny is too low the dist will hit the firewall. I'd pull the dist and maybe the crossmember and I'll bet she'll go.
post #12 of 20 (permalink) Old May 14th, 14, 04:40 PM Thread Starter
Ove
I'll try to remove the distributor, and loosen the crossmember tomorrow, simply because both the engine and frame mounts looks correct. But as it is now, there is only about 5mm between the transmission oil pan, and the crossmember, i am afraid if i manage to get the engine seated on the mounts, i wont be able to put the crossmember or distributor back on...
post #13 of 20 (permalink) Old May 14th, 14, 04:42 PM Thread Starter
Ove
And yes, i've been jacking up the transmission. It's not a HEI distributor.
post #14 of 20 (permalink) Old May 14th, 14, 06:36 PM
Smile Re: Mounting holes for engine frame mount
The frame mounts look fine. Put the engine in without the distributor cap on. Once the engine is in, raise the rear of the transmission which will create more room at the firewall and then re-install the dist. cap.
TJS69 is offline
post #15 of 20 (permalink) Old May 14th, 14, 08:41 PM
Timmy
I borrowed a 396 Bare Block and heads to mock up my Headers and Transmission Crossmember for a SB TH350 swap to a 427 700R4 Trans upgrade, been in the garage late, and saw your Post.
I thought there were some Questions about Mounts and what they should look like, hope these Pic's help, I realize your Parts might be different.
I have the 3950113 L/H Frame mount and 39501134 R/H Frame mount Bracket and Energy Suspension 2 3/8" wide "Long BB Mounts".
I did put a Line with a magic marker down the front middle of the Block and then after I installed the Block, measured for the 1" offset to the Right/ Passenger side - Mine is Perfect. Measures 14" to the Right Frame rail and 15" to the Left Fame rail.
I will also be installing the Trans and Crossmember looking for the 1/2" offset to the Right/ Passenger Side.
Hops this helps, Have the Pictures with my Doug's Headers Installed too but will be posting that in another Post I started.
Timmy from Trumbull, CT
ID:	72986   Click image for larger version
ID:	72994   Click image for larger version
ID:	73010   Click image for larger version
french69ssrs is offline
