Max Safe RPM For This Engine - Team Camaro Tech
post #1 of 3 (permalink) Old May 20th, 14, 09:33 AM Thread Starter
Joe
I have the rev limiter set to 7500, but it hits the limiter so easily, that I'd like to raise it to 8000. The engine makes max HP at 6800 RPM and the drop off is not fast at all. I need another dyno test to get a better idea because the last dyno test was done with retarded timing.
This is a small journal 327, .030 over with Crower Sportsman rods using 3/8" bolts. Piston clearance is .0055" because the block is 3/4 filled with Hard Blok, piston to head clearance is .035", static compression is 11.3:1, horsepower is 475 @ 6800. Oil pump relief spring is 70#, using 20W-50 Castrol.
1965tripleblack is offline
post #2 of 3 (permalink) Old May 20th, 14, 10:16 AM
Anne
Re: Max Safe RPM For This Engine
Sounds to me like you want to grenade this engine.
If you want better quarter-mile times, is everything else optimized ?
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
post #3 of 3 (permalink) Old May 20th, 14, 10:26 AM
Joe is you are making MAX power at 6800, I would not increase your rev limiter at all, just cuz ya can wind a motor up, doesn't mean it will last long doing so.
I would suggest differant gearing, if your hitting rev so easily.
PhantomRider is offline
