Power Steering Pump Housing Question - Team Camaro Tech
post #1 of 27 (permalink) Old May 21st, 14, 01:02 AM Thread Starter
69z28freak's Avatar
Here is a crazy question, but will this power steering housing be an issue. I swapped power steering housings today. The top one is the old one and it has a curved flange compared to the one on the bottom which is straight. I am just wondering if it could present any type of a clearance issue. The bottom housing is from my six cylinder motor. I didn't think about that potential issue. I won't know if I will have a clearance issue until the motor is in the car. If it is an issue I will have to pull it and replace the housing with a curved spout/flange. Hopefully someone has seen this situation before and can advise me. At some point I am going to really excited about not having to learn the hard way!
Grandma, 69.5, Z/28 Finally Done! Well almost...
My Build Thread
69z28freak is offline
post #2 of 27 (permalink) Old May 21st, 14, 02:08 AM
Garth
Re: Power Steering Pump Housing Question
You mean the pipe outlet, right ? The top one is correct as the hose will go in under the oil pan, parallel with the cross member. There would be interference problems with the cross member using the bottom one (6 cyl). Check your AIM...
Garfields Maro is online now
post #3 of 27 (permalink) Old May 21st, 14, 01:33 PM Thread Starter
69z28freak's Avatar
That is what I was afraid of. I will powder coat another can with a curved outlet pipe and swap it out.
My Build Thread
post #4 of 27 (permalink) Old May 21st, 14, 06:21 PM
Hmmmm.....I "assume" mine to be original to my small block car, and it looks like the bottom one. Not even close to interfering with the crossmember as the crosmember has a large relief there.
BPOS is offline
post #5 of 27 (permalink) Old May 21st, 14, 06:59 PM
Garth
hmm, is right. I ain't so sure yours Al, doesn't have more bend to it than Mikes lower pic ? It needs plenty of room for belt adjustment.
Anyway, if you check the AIM, L6 and V8 use different pump assemblies. I'm not sure, but think the difference is in the pipe outlets.
post #6 of 27 (permalink) Old May 21st, 14, 08:14 PM
Tim
FWIW, mine looks like the top picture too Mike.
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Sold Clippinger Chevrolet. Raced at Lions in LA.
ZLP955 is offline
post #7 of 27 (permalink) Old May 21st, 14, 08:41 PM
This is exactly like mine http://www.heartbeatcitycamaro.com/s...p-all-SB-1969/
BPOS is offline
post #8 of 27 (permalink) Old May 21st, 14, 10:36 PM Thread Starter
69z28freak's Avatar
Thanks Al that is great news. I just wanted to be sure. I would hate to get my car ready to drive and then have to mess with another power steering bucket! I am also going with the same set up as you on power steering brackets. I made a spacer just so I could size it out properly and then I will source a nice one like yours. Did you have any alignment issues with your power steering pulleys so that the fan belt turns true. Mine look like they will line up, but I won't know for sure until I get the belts on. Hopefully this week.
My Build Thread
post #9 of 27 (permalink) Old May 21st, 14, 10:51 PM Thread Starter
69z28freak's Avatar
Hey Garth my car came with the six and used the same power steering pump. even though the tubes are bent, they still look like they resend pretty close to the same length. I will not know for certain unless I try it out, or swap the cans before I install the pump.
My Build Thread
post #10 of 27 (permalink) Old May 21st, 14, 10:55 PM Thread Starter
69z28freak's Avatar
Hey Al looks like there are several different bends in the tubes on various pumps. Big block tubes for example turn to the left with a more pronounced bend. The one in the picture you posted is for most small block cars. The straight one like mine is only for the six cylinder cars. I am not convinced there will be a clearance issue, but I would like to know for certain, so I don't have a clearance issue when I install or have to swap cans out again. I guess the question is. HAs anyone ever installed a straight tube unit on a small block car? I think the big block motor sits lower in the car if I am not mistaken??
My Build Thread
post #11 of 27 (permalink) Old May 21st, 14, 11:01 PM Thread Starter
69z28freak's Avatar
Thanks Tim I am investigating now to see if I am safe or not! Wish me luck.
My Build Thread
post #12 of 27 (permalink) Old May 21st, 14, 11:21 PM Thread Starter
69z28freak's Avatar
Here are some pics showing the difference.
ID:	73737   Click image for larger version
ID:	73745   Click image for larger version
My Build Thread
post #13 of 27 (permalink) Old May 21st, 14, 11:37 PM
Garth
Is the curved tube pump off your 68 ? Don't know if the year makes a difference ( I doubt it), but it looks just like mine.
post #14 of 27 (permalink) Old May 21st, 14, 11:43 PM Thread Starter
69z28freak's Avatar
The straight tube is off of the six cylinder 1969. It is the same car. I started out with the 6 and am doing the restoration on the six, only now dropping in an 8 cylinder.
Here is a better picture of the straight tube from the six/pump.
Both tubes seem to drop down the same length, even though one is straight and one is curved. So unless the position is an issue, it looks like it might be ok. As long as the tube does not hit the subframe. However if you look at Al's picture it does look like there is a lot of room there.
My Build Thread
post #15 of 27 (permalink) Old May 21st, 14, 11:48 PM Thread Starter
69z28freak's Avatar
Hey Al what finish is on the spacer between the alternator bracket and the header. It looks like the same finish as your header.
My Build Thread
