Dead and backfiring - Team Camaro Tech
post #1 of 12 (permalink) Old May 21st, 14, 06:04 PM Thread Starter
Dead and backfiring
Alright guys I'm fairly new here and this is my first post got a problem gonna see if you guys had any ideas: so I took my 69 for a spin today whole drivetrain is fresh as of about 120 miles ago carb 582bbc/th400 anyway so I'm driving down the highway and start to notice the batt gauge going down finally it bottoms out and next thing I know the speedo starts to fade out then the tack and eventually everything I manage to get almost gone and the car starts wanting to die so I shift to first and 2800 rpm to limp back I let off the gas to turn into the driveway and it back fires hard and dies out Turn key absolutely no power no starter fuel pump or anything. I then wait about 10 min try the key again and heard the starter click I then turned the key off and left it sitting halfway into my shop before I started throwing sh it. Just got done fixing 5 other things and now this. What are y'all's thoughts?
S.O.B is offline
post #2 of 12 (permalink) Old May 21st, 14, 06:36 PM
Anne
Re: Dead and backfiring
Have your alternator tested.
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
post #3 of 12 (permalink) Old May 21st, 14, 06:47 PM
jno
X2 bad alternator, or loose battery connection. Had the same exact thing happen years ago on a 3rd gen camaro. Car should run off the alternator, but instead it slowly drains the battery until it is dead.
jno is offline
post #4 of 12 (permalink) Old May 21st, 14, 07:57 PM Thread Starter
That's what I figured. But would that explain the back firing too?
S.O.B is offline
post #5 of 12 (permalink) Old May 21st, 14, 08:45 PM
Jon
Not enough juice to fire the plugs at the right time, so it backfires.
Jon N
dyno jonn is online now
post #6 of 12 (permalink) Old May 22nd, 14, 01:06 AM
69-Pace's Avatar
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #7 of 12 (permalink) Old May 22nd, 14, 06:11 AM
Jeff
Did you solve your overheating problem? Was it the radiator?
And this too shall pass.
69 X11 SS, Glacier Blue, LS3 480, T56 Mag, Lots of stuff done to it, all by yours truly
Build thread:
workng247 is offline
post #8 of 12 (permalink) Old May 22nd, 14, 07:37 AM Thread Starter
Yea man I switched in the new setup fans and rad and it's runs around 170 now
S.O.B is offline
post #9 of 12 (permalink) Old May 22nd, 14, 07:42 AM Thread Starter
O yea man. Swapped on the new rad and fans it runs around 170 now. Highly recomend those guys in michigan can't remember the shops name off hand
S.O.B is offline
post #10 of 12 (permalink) Old May 23rd, 14, 11:38 AM Thread Starter
Sure enough the alternator was fried. Why would that happen. Do I need to put a regulator or something on this new one or was it just a defective unit y'all think? It's a one wire btw
S.O.B is offline
post #11 of 12 (permalink) Old May 23rd, 14, 10:31 PM Thread Starter
Alright its over charging even with the new alternator. What the hell doi do?
S.O.B is offline
post #12 of 12 (permalink) Old May 24th, 14, 02:49 PM
69-Pace's Avatar
Well I'm not a fan of one wire but sounds like the internal VR is confused or toast. Is it about 14 volts? Even though this document is against one wire systems also you might glean some helpful advice. http://www.madelectrical.com/electri...hreewire.shtml
69-Pace is offline
