Adjusted Rockets now it's sputtering a bit... - Team Camaro Tech
post #1 of 6 (permalink) Old May 25th, 14, 09:49 AM Thread Starter
Jeremy
Hi All,
So I had a tick in the engine, did some research and the general consensus is that is probably either an exhaust leak or a lifter.
Well I wanted headers anyway so I got some Doug's Tri-Y's and some flowmasters and they sound awesome but the tick remains unchanged so I will assume that the lifters could use an adjustment.
I did some research and watched a few YouTube videos on how to do it with the car running. It seems like the best way is to back off the rocker just until you start to hear it clack and then tighten anywhere between half and full turn (this seems to be down to personal preference based on what I read...) anyway so I went with 3/4 a turn.
Ok so the tick is not 100% gone but definitely way better but now it's sputtering around 1/4 throttle. If I mash the pedal to the floor it goes great.
So I am a newbie mechanic for sure so please chime in if any of that sounds way off... I assume that by messing with the rockers my previous good timing is now been thrown off a bit, does that make sense?
Any other advice or comments on my chosen method would be greatly appreciated.
Thanks in advance
jeremywrags is offline
post #2 of 6 (permalink) Old May 25th, 14, 10:17 AM Thread Starter
Jeremy
Re: Adjusted Rockets now it's sputtering a bit...
Gotta love the iPhone autocorrect, hopefully it is clear that I adjusted the rockers and not the rockets...
Moderators can you change the post title to rockers please?
post #3 of 6 (permalink) Old May 25th, 14, 01:37 PM
Rufas
You need to look into the Comp Cams "E-O, I-C" method for adjustment, and NOT do it with the engine running.
dave ray is offline
post #4 of 6 (permalink) Old May 25th, 14, 06:38 PM
You didn't say whether you have solids or hydraulic or roller lifters. If you have hydraulics FT lifters then you set them correctly while running. Add 1 bottle of EOS Engine Oil Suppliement, it's for sticking lifters.
COPO is offline
post #5 of 6 (permalink) Old May 25th, 14, 07:21 PM
Robert
Probably have one too tight and its not closing completely causing the "sputter". I prefer the E-O I-C method with 1/2 turn after 0 lash for hydro FT. Did you inspect the push rods, check both ends and roll on a flat surface to check for straightness. Could be other issues that adjusting won't help but that's a good starting point. Also, adjusting valves won't change the timing.
Robert
TC member #18
rojo is offline
post #6 of 6 (permalink) Old May 26th, 14, 06:15 PM Thread Starter
Jeremy
Hi all,
Thanks for the input. I took my time and did some research and went with the cylinder 1 Tdc then adjusted the first set of 8 then cylinder 6 tdc and adjusted the other 8. I went with a half a turn on each rocker and it seems to be running like a champ.
Tags
rockers, tick, timing, tucking
