ZZ702....709HP/679#/ft.... - Team Camaro Tech
post #1 of 5 (permalink) Old May 27th, 14, 03:33 PM Thread Starter
Chris
Gen 6 ZZ502 Transformation
4.500 x 4" Stroke with 6.535" Rods
Canfield 310 Heads by Foxwell
Heads have Scotts new Chamber design
10.5 to 1 with SRP Pistons
2902 Out of the box
Hyd Roller 246/248 660/610" lift on 107 Sep
Morel 4603 lifters
93 Octane BP 10% Ethanol
37 Degrees total
AED 850
MSD Distributor, 85551
1" Open Spacer
Torque
4800 rpm 679.6
HP
5800 699
5900 702
6000 706
6100 707
6200 709
6300 709
6500 707
6500 702
http://www.chevelles.com/forums/showthread.php?t=622018
Chris
cstraub is offline
post #2 of 5 (permalink) Old May 28th, 14, 04:37 AM
Re: ZZ702....709HP/679#/ft....
Very nice, Mr. Straub.
Wonder the difference if EFI where used?
I believe the numbers would be less, but would driveability be alittle better?
Yes, I know its not a street engine, especially with 107 LSA, no sleeper here.
post #3 of 5 (permalink) Old May 28th, 14, 07:57 AM Thread Starter
Chris
Everett,
Its a driver. Dont' let the 107 bother you. It idled at 900 no problem and yes you knew it had a cam but it was crisp, not blubbering. EFI should make the same power with some tuning. Will have a GoPro of it in few days. Box stock 2902 and the AED850 was out of the box.
Chris
Chris
cstraub is offline
post #4 of 5 (permalink) Old May 28th, 14, 10:36 AM
Steiner
I don't know, kinda weak for 702ci.
'69 Camaro
500hp/538lbft
Steiner is offline
post #5 of 5 (permalink) Old Jun 7th, 14, 06:22 PM
Jon
That's a big powerful motor. Could you drive it on the street?
79 Camaro
489 BBC
Turbo 400
2ndGenBB is offline
