New LS3 EROD or used? - Team Camaro Tech
post #1 of 2 (permalink) Old May 27th, 14, 11:20 PM Thread Starter
Rob
robsutt's Avatar
Need some help here cause from what I can tell it seems to make more sense for my CA 68 RS Conv to buy a new LS3 EROD versus look for a used motor. Am I off base? Not really seeing the benefits of used here.
robsutt is offline
post #2 of 2 (permalink) Old May 28th, 14, 08:22 AM
Re: New LS3 EROD or used?
For the $$$$$ I would go used and rebuild (mileage dependent) there are pull-out motors out there also.
If you're not into parts hunting, it may be the deal you want going GM-new.
Do NOT go with the GM hot rod pan....it hangs about 2" below the crossmember
Any LS with a cam (and maybe springs depending on cam) will really wakeup an LS.
You may get lucky and find a low mileage wreck too ??
68 Camaro~LSx ~all motor
